Question about Whirlpool LER4634J Electric Dryer
DRUM TURNING, BUT NO HEAT TO IT...CHECKED AND NO BLOWN BREAKER OR FUSES...WHAT DO I CHECK NOW?
  • 96 Answers
Make sure that you have 240volts at the back of the dryer. If you do, unplug , remove rear cver and check thermal fuse and thermostats with an ohmeter
Posted on Mar 26, 2011
No heat Is the drum turning? yes Is heat selected? yes
you will need to check the thermal fuses they are located next to the heating element.If you have a volt meter you will need to check the continuity on all the thermal fuses and the heating element replace the part that has no continuity.
There are times that the main circuit breaker can be bad you may need to check the power and make sure there is 220 volts to the unit.As you check the thermal fuses and heating element make sure the unit is unplugged
Mar 18, 2011 | Dryers
Whirlpool electric dryer not running.
Check the blown fuses and home's circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Dryers
I own a Maytag Atlantic that is only blowing cold air no matter what cycle I set it in also when I open the door the light is not turning on, could this be related and what the causes may be?
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer has no heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check the lint filter and exhaust duct is clean.
Select the heat setting other than Air Fluff.
Jul 02, 2010 | Samsung DV448AEE Electric Dryer
IT RUNS BUT DOES NOT HEAT
Jul 02, 2010 | Roper Dryers
Dryer runs but dosn't heat any ideas would be appreciated
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Jun 16, 2010 | Miele Novotronic T220 Electric Dryer
Won't heat
Jun 16, 2010 | Whirlpool LER5636P Electric Dryer
Dryer heat not working
Jun 16, 2010 | Whirlpool GEW9200L Electric Dryer
Maytag med5740tq0 will heat up but drum does'nt turn
This could incidicate one or more problems. One of which could be that your belt is broken and no longer turns your drum. part number for the belt is 8066065 which is better known as a 341241. this is a common problem and can be replaced by removing the drum. The other possible cause of the drum not turning could be a blown fuse inside your home. This will allow the heater to work but not the motor since they both take 110v. If your fuses are okay, you could also have simply a burned connection. I would visibly inspect these and then have it checked by a technician if they check out.
Thanks
Oct 14, 2009 | Maytag Dryers
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
