Question about LG 42LG50 42 in. LCD HDTV
Hi,i have lg5000 42" when
  • 1,591 Answers
Either one of the inverter boards has a failing capacitor on it, or the FL (backlight) tube is burning out.
in your case, the most likely suspect is the tube.
The easiest way to find out if it's the tube or the inverter board, is to plug each of the tubes into the others inverter. This isn;t possible on all models because of wire length, but in most cases it can be done.
If you have the same problem on the same side, it's the tube
If the problem moves to the other side, it's the inverter.
You can either look for failed caps on the inverter, or just replace the inverter - the former being much less expensive if it's just a capacitor or 2.
If it's the inverter, here's a video that might help you out in determining what capacitors have gone and how to replace them.
http://www.youtube.com/watch?v=Mm51C_RDIZE (this is part 1/2)
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related (part 2/2)
IF it's the backlight you'll have to get the make and model of the LCD panel itself, and then go to somewhere like www.lcdpanels.com to order the backlight (or the entire panel if you don't think you can replace the backlight without damaging the panel).
Posted on Mar 25, 2011
  • 9 more comments
  • Todd Hill
    Todd Hill Mar 26, 2011
    tube?
  • Norman Skinner
    Norman Skinner Mar 26, 2011
    Yes, flat panels have a fluorescent tube or 2 in them to provide backlighting - they are connected to the high voltage inverter boards.
  • Todd Hill
    i call a tube a crt and lcd's have as many as 20 ccfl's in a 42 inch min. 4 in a 13" lcd have never seen a lcd with one or two ccfl's
  • Todd Hill
    and i think it is amazing that it is only a 56khz signal on inverter trans. don't you?
  • Norman Skinner
    Norman Skinner Mar 27, 2011
    if you've never seen an LCD with only one or 2 FL tubes in it, you've never repaired a laptop!
  • Norman Skinner
    if you want to know the REAL frequency there, check herehttp://en.wikipedia.org/wiki/CCFL_invert... where you will see inverters for laptops which have...you guessed it...ONE output for ONE CCFL because that's all the laptop used!
  • Todd Hill
    Todd Hill Mar 27, 2011
    thats laptops i thought we were talking about lcd's were are we going with this?
  • Todd Hill
    and the real freq. is?? tell me am i wrong? lcd tv lcd tv
  • Todd Hill
    one output or one ccfl?one cfll ..no
  • Todd Hill
    we will never agree
  • Norman Skinner
    Read my post, yes, ONE CCFL - most laptop LCD panels up to about 15" usually only use one tube, larger ones will use 2.
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
I have a InFocus 4805. Half the picture is darker
Your light tunnel may have collapsed. This is made up of 4 tiny rectangular mirrors glued together to make a tunnel.
Sep 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
Half screen lighter than other half
faulty display panel or faulty display driver
Aug 31, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
LG 42LG50 42 in. LCD HDTV Logo
296 people viewed this question
