Question about Sony Playstation 3 (PS3) Console
My ps3 wont start, you can plug it and it has a red flashing light, wont power on or nothing, cant even soft start it. what is and what can i do. any help will be very appreciated
    Novelist:
    Sniper:
  • 90 Answers
Hi frankie,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Posted on Apr 09, 2011
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
My PS3 Wont stop flashing red, the little red light keeps flashing and will not even power up the console. I cant use my ps3 at all.
I had the same problem. Phoned sony and they said I would need to send the console back for repair which would cost a small fortune :(
I googled about and found an ebook that seemed to 'promise' that it could guide you through fixing it at home.
Suffice to say it worked and haven't had a problem since.
Link I found was :
http://bit.ly/hLABB0
It's cheap enough and worked for me. Let me know if you got on ok! Good Luck!
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
Wont turn on flashing red light
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
· c Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
· Leave the PS3 system off for 30 minutes to let it cool down.
· If you continue to have issues, you will have to send the system in for service."
Hope this will help..
May 27, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: i had a power cut whilst playing ps3 , now it wont...
First thing to try is a video reset.
While the PS3 if off (red light solid) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if this works, otherwise we'll try step 2.
May 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
The game system will not turn on.it flashes a yellow light
What model is your PS3? 40 / 60 / 80 etc.
I can help you with this problem or at least give you low down on what's going on.
Mar 03, 2009 | Sony Playstation 3 (PS3) Console
Playstion 3
I understand how frustrating that must be. How big is the hard-drive that came with your unit? Did you buy it brand-spanking new or used? Update to version 2.2. It came out last night. Then, once that is complete, shut down your PS3. Unplug everything from your memory card ports and usb slots. Unplug the power cable at both ends (from the wall and the ps3). Then switch the PS3 hard switch (on off, lever, not the soft method of turning it on by a mere touch). Leave it that way for 10 minutes. Plug power cable back in at the PS3 and then at the surge protector/power-strip (wall). Turn in on with the switch and then use the soft method (described above) on the front. That should fix it. If not, send it back for a warranty exchange. Good luck.
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Wont turn on
I don't think the outlet you are plugging it into has enough power to support the ps3. Try plugging it into a different outlet and see if it works.
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
348 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
