Question about Garden
Im in the uk trying to remove cover what sort of screws are used cant get them out ...thx larry
    Master:
  • 403 Answers
What are you talking about
Posted on Mar 25, 2011
My pc is 2 months old and i cant burn audio cds it just burns the covers of the album im trying to burn ive replaced the cd drive twice any ideas anyone thx
what program you use to burn the CDs?
i suggest you to use NERO.
its highly recommended.
please vote my answer so i can give more next.
Mar 07, 2011 | Enlight Combo (5601908) (Beige) (5601908)...
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
Cant get into boot
hi from uk as a getz owner(my wifes car) i do understand problem may i suggest this is most probably the lever on rear of the lockwhich is behind the cover on boothatch is probably loose hence when key is used the lever that connect to rod link and releases latch is slipping on key lock operation but when c/locking is used on drivers door it opens boot latck by motor no problem SO remove the panel from hatch held by screwsnear screen and pop plastic buttons on surround you will now have visual access to lock mech's and by using info provided above ? i am sure you can sort the problem if you use both key in lock operation and c/locking method to observe linkage it may be as suggested or a simple little ajustment of rod linkage hope this helps/inspires you ? best wishes from n/west uk lanc's
Dec 01, 2009 | 2003 Hyundai Accent
How do I remove door panel to get to the motor ?
Ive yet seen a jeep window come off track. sounds like your window regulator is broke but hopefully im wrong. anyways, remove all the screws some have cover over them, just remove the cover and youll see some sort of screw. Then pull out and try not to breake the plastic clips that pop into door. its pretty easy once you just look at if for a min. let me know if you have anymore questions about this
Apr 07, 2009 | 2001 Jeep Grand Cherokee
Remove cable
I have the same monitor and it should be screwed to the PC and have some sort of protection over the screws so you don't see any screws on it...
It's there...the screws...
Jan 26, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Dashboard removal... gets stuck on the steering wheel base
I can't help you with the srew, it takes what ever it takes to remove it, have you drop the steering column dowm by removing the column clamp on the bottom of it, you have to drop the column to get enough room.
Sep 26, 2008 | 1995 Chevrolet Blazer
Window Off Track
there should be a couple of screws behind some plugs in the door handle (the one you pull to close the door) also if it hasnt got power windows theres a metal clip at the base of the winder small flat screw driver to pop it off also remove plastic inside top off door trim near mirror also inside door lock then try lifting upwards
Jun 03, 2008 | 1995 Audi A6
Looking for disributer of asus spare parts in the UK
not too sure about what it is you need but take a look at this site. http://www.servicesource.co.uk/frameset.asp?top=maintainer.htm&main=stock_check.asp
May 03, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
