Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Hose Collapses When I Try to Use Wand
When I try to use the wand to vacumm furniture, the hose collapses and there is no suction. . How do I solve this problem?
  • 1 more comment
  • Anonymous Aug 04, 2008
    My dyson does the same thing. The hose collapses whenever I try to vaccum with the hose.
  • Anonymous Apr 11, 2009
    How do you put the value pipe back on a dyson animal vaccum?
  • Anonymous Apr 12, 2009
    Same thing... when I'd try to use the wand, the hose would collapse on itself.  Took the wand off the hose and found a chuck of "dog toy" stuck towards the handle part of the wand.  I took a little bit to get everything out, but it's all clear and working like new again!
  • 372 Answers
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Posted on Aug 06, 2008
I had the same problem.  I removed the wand and found a button causing the blockage in the wand.  I used a sewer snake to remove it.  So start by detaching your wand from the hose and checking for blockage.  If you can't see daylight by looking thru the wand, you've got blockage that's causing your problem.
Posted on Apr 04, 2009
Dyson no suction in upholstery wand
Hi there, it's Jack at Dyson.
Like most Dyson upright vacuums, DC18 is engineered to divert suction to the hose and wand automatically when it's standing in the upright position. If your DC18 doesn't seem to have suction from the wand when standing upright, you may have a blockage in the hose or wand. Please follow the steps shown in our online Support guide to check for this: http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/remove-the-wand-from-hose
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 horus for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue. However if you'd like any further guidance from our experts after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 27, 2014 | Dyson DC18 all floors Bagless Upright...
My Dyson DC07 vacuum works on the floors, but when I pull out the extension wand the coiled hose attached to the wand collapses and no suction goes through the hose?
Hi there, it sounds like you have a blockage in the hose. I have made a video to show you how to get the hose off and linked it to this answer. It is possible to split the hose in places trying to get the blockage out so try not to be rough. If you do damage the hose you will need to buy a new DC07 hose it is a waste of time trying to repair. If this was a helpful answer please take a moment to rate it or leave a testimonial.
Feb 20, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
The hand held attachment no longer has suction. The hose collapses when I try to use it. Have cleaned the vacuum thoroughly and the filter. This still happens. Ive taken all the parts off and cleaned...
Hi, please ensure that the hose is fitted correctly into the base of the Dyson. If this becomes loose or detached the machine will not **** whilst using the hose. Also check that the u bend is fitted correctly. Finally check that the vent on the left hand side (when standing behind the machine) is correctly inserted. The other issue could be that the Wand itself is blocked. Try detaching the wand from the hose and see if the hose has suction. If it does then the wand is blocked, if it doesnt then the problem lies elsewhere.
Nov 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you remove the hose to ck for blockage?
If the hose collapses and there is no suction, that is a sure sign of a clog. The clog will be on the opposite side of the collapsing hose from the motor. Good luck.
Mar 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal Hose collapses
The blockage is in the wand itself - take it off the back of the machine and separate it from the gray hose. Hold the wand into the air and look through it. If you don't see the light coming through the other end, there is a blockage in the wand. Remove it with a long object like a metal hanger. The DC07 wand is slightly bent at the top - you should still see some light coming through the top though. Be sure to look through the metal rod end of the wand, otherwise you probably won't see anything anyway.
Jun 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Attachment hose collapses when using wand
The thoe or the wand is clogged. Remove the hose at the machine end, reverse it and turn the machine on. This should **** the blockage out, the way it got in. If you hear the motor straining, it's still clogged. I've already taped a small hook, like a screen door hook onto a broomstixk and fished into the blockage to remove it. Be carefol. If you puncture the hose by pulling too hard, the hose will be ruined. Tahe your time and look for something unecpected, like a toothpick or a LEGO piece. They and vacuum cleaner friendly.
May 25, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
The extension arm of my Dyson Animal no longer has any suction. I can attach it but it has extremely limited power to reach high places or under furniture. Also, when I stand the unit, used as vacuum,...
you have a blockage within the wand or at the u-bend at bottom of the hose....try removing wand and see if u hav esuction at end of hose...if so wand is blocked,if not removed u-bend
Oct 07, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
2,706 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
