Question about Vizio VP322 32 in. Plasma TV
I have a Vizeo vp322. first it would not come on at all so I found the bad caps and replaced them now after 2 months it will work for about an hour then shut off. it appears there are no bad caps. any ideas?
  • marionbagget Mar 25, 2011
    Did you replace with high temperature, low ESR (equivalent series resistance) ripple resistance caps ?
    President:
  • Vizio Master
  • 1,779 Answers
You will have to check your Vs, Va and 5 volts coming off the power supply to make sure they are exact. The Vs and Va voltages will be posted on a sticker on the top of the display panel on the back side. You are treading into an area that does require technical ability to rectify or you will waste money on un-necessary parts. In most cases when caps are going bad they fatigue other semiconductors, usually on the Y sustain panel. Plasma power supplies are totally different from LCD when it comes to just replacing bulged caps. I recommend a qualified technician look at this particular problem for you.
Posted on Mar 25, 2011
  • Rocky Jun 02, 2011
    You can also buy the whole power supply from www.interliquidparts.com you have to open up the TV and get the part number of the power supply from the actual part.
  • Leslie Jan 15, 2012
    I also have a Vizio VP322 that died. No logo lights, no picture, nothing. I replaced the bad caps and it worked for about 30 min, then the screen went black. When powering on, the logo does turn from orange to white, but then it stops. I changed the 4.0 A 250v fuse on the Ysus board and the screen still won't light up. What other components could cause this? I know I can purchase a new power board, but if I can fix it, I'd like to.
  • 24 Answers
I have fixed two of these models in the last week both with no power:1st one I replaced 5 capacitors which fixed it.2nd one I fixed I replaced 2 shorted out capacitors,you could hear it turn on then off.Before it shut down the vs voltage was 208 volts where it's supposed to be 195 volts,adjusted down to 195 and that fixed it.Hope this helps
Posted on Dec 05, 2012
Engine Rotates (acts as it will start) won't fully turn over.
Did you replace the TPS (throttle position sensor)?? Try that if you haven't so. But if you did that already, and still getting the same problem, I would suspect the fuel pump going bad.
Apr 12, 2014 | Cars & Trucks
Had the video card replaced and 6 months later no sound only a high pitch noise. What is wrong with it?
fans bearings are going bad. lube or replace the whole fan. it also could be powersupply, they make a high pitch squeal sometimes when going bad.
Mar 24, 2011 | Vizio VP322 32 in. Plasma TV
I have a sony kdl46xbr9 that after gaming or blue-ray for an hour the tv will shut of and back on again and do this until you turn the tv off. they come today and replaced the main board and after a short...
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 11, 2010 | Sony Televison & Video
Vizio vp332 will not power on
It sounds like a powersupply problem. Bad caps on the board. I've found some vizios with bad caps along the aluminum heat sink.
May 31, 2010 | Televison & Video
I have a VP322 32" Plasma TV with bad capacitors
Temp is not the problem you need to replace with higher voltage rating this is a 12v board how many 10v caps u gots?
May 30, 2010 | Vizio VP322 32 in. Plasma TV
I purchased my Vizio VP322 HDTV10A just about 1.5 years ago for almost $600 at WalMart. For the past 4 days or so when I turn it on it will cycle on/off numerous times before powering up and staying on....
its bad capacitors on the power board
if you can solder, you can fix it.
look for caps that are bulged up, theyre supposed to be flat on the top. google bulged caps and youll see pictures
replace with same value parts to solve, all are solder in
May 21, 2010 | Vizio VP322 32 in. Plasma TV
It won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 13, 2009 | Vizio VP322 32 in. Plasma TV
I go to turn it on and the vizio label turns white then clicks off
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Nov 12, 2009 | Vizio VP322 32 in. Plasma TV
After about an hour picture gets a blue distortion. YOu have to turn off TV and let cool off. Once it cools off it works until it gets hot again.
replace these electrolytic caps in the power supply,
C233,C234 3300mf/16volt
C241,C238 470mf/35volt
C236 1000mf/25volt
you can also go to shopjimmy.com enter model number scroll down to find power supply if they dont have it in stock write down the part number to find it on the web,it would be cheaper for you to replace the bad caps.
Sep 24, 2009 | Vizio VP322 32 in. Plasma TV
New vizeo 32" LCD TV -- black and white?
check to make sure that both are tuned to the same chanell.
Lou Margolis
Allied Electronics
loumargo@verizon.net
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VP322 32 in. Plasma TV Logo
388 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
