Hi i have a packard bell easynote tj65 running windows 7 ultimate x32 bit after the unit has been off for any period of time after startup the screen resolution is all wrong and seems to adjust its self and im unable to see the logon options or start menu ive uninstalled the display drivers and downloaded the latest from packard bell direct still have the same same issue ive noticed that before the problem starts during startup i dont see the splash screen with the option to enter setup i need to manally power the laptop off from the power button and then restart before it will boot correctly
  • eddie connelly Mar 26, 2011
    update on the issue ive now installed a fresh copy of windows and updated everything to date still have the same issue ahrrrrr doing ma head in think it might be a graphics chip issue
mewms_14904
  • 1027 Answers
SOURCE: Packard Bell Easynote M5255 - Will not boot up
option f2, go into bios setup and see if the hard drive is listed or detected. Auto detect hard drive save and exit. System will reboot if the same error occurs then the hard drive master boot record is probably corrupt or the hard drive has totally failed.
Posted on Apr 19, 2008
ibleedblue18
  • 50 Answers
SOURCE: Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Posted on Dec 07, 2008
  • 107 Answers
SOURCE: packard bell e1245 crash
try press f5 when system is starting up then go safe mode, then try to restore your system to earlier setting with system restore. system restore is located on start/accesories/systemtools/system restore.
Posted on Mar 05, 2009
SOURCE: i cannot activate bluetooth in packard bell
buton Fn+F6 and start bluetooth
Posted on Dec 11, 2009
  • 50 Answers
SOURCE: cant seem to make the icons smaller on display
If you are using Vista/Windows 7 Right click anywhere on your display and you should get an option under view to change the size of your icons or you could change the display ratio/screen resolution which will automatically adjust icon size the higher the display setting the smaller the icon.
Posted on Jan 29, 2010
My Packard bell tj65 won't show toolbar
May be OS miss. You can unplug your RAM and then plug it again then try it again. If it display same thing then recover your operating system from system reboot system.
Thank you
Sep 07, 2016 | Packard Bell Easynote Tj61 Windows 7 Hdmi...
"Consider replacing your battery"
Modern batteries do talk to the laptops and provide information on health. Ordinarily, this message would mean that your battery is on its way out. If however, it holds its charge then fine, but at some stage you may find that you only get a few minutes use even on a full charge and you will need to find a replacement.
Leon
Feb 09, 2013 | Packard Bell Computers & Internet
My Packard Bell Easynote Z94T laptop has no audio output after windows 7 upgrade - help!
Packard-Bell.DriverUtilities.com go to device manager and uninstall the current driver. prompt will then come up stating new hardware found and will ask you to chose a location to install from. go to P-Bell site and upload driver once in the download file you can open the driver file. I also suggest you go to Microsoft Security Essentials and run a quick scan of your computer( this will update virus definitions and remedy many latent computer issues.
May 21, 2012 | Computers & Internet
How i can findout mac address for my packard bell easynote tj65? and how i can connect to the belkin router?
The MAC id is often on a sticker on the bottom. If not you can access it through control panel. What version of windows are you running?
Most versions you can click Start, then Run, and in the box type ipconfig/all
Jul 01, 2011 | Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
Laptop not working wirelessly
Your router may be excluding the mac address for your easynote TJ65
Feb 18, 2010 | Computers & Internet
Cant seem to make the icons smaller on display packard bell easynote tj65
Jan 11, 2010 | Computers & Internet
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
