Question about Garden
Fan is giveing bad voice. - Garden
  • 784 Answers
Is it metallic voice?
Posted on Mar 25, 2011
Mismatch of application settings no voice mail. how to fix
some phones have virtual voice mail...which means you must syc it with the service voice mail ... if voice mail is pass word protected ...you must program the voice mail password and information into the virtual voice mail or it will not retrieve messages or give you notification of incoming voice mail.. The directions they give you for this is really asinine and hard to understand. Call your service provider they will be able to help you.
Mar 11, 2015 | LG G2 Black Smartphone - Verizon Wireless...
Is it possible to reduce the background music when watching a dvd? The music overpowers the voices.
No. The reason they give Academy Awards to SoundMixing, is because some do it great, and some do it bad. Once the dvd is printed, there is nothing you can do about the mix of the sound between background and voices. it's just a bad mix. oh well, the same thing happened to me about a week ago, but as the movie went on, the sound mix either got better, or my ears started to tune into the voices better.
Mar 03, 2015 | Televison & Video
Computer shuts down every 60 secs;delete switch user
i would check to see if your fan is working ,need more info though does it give you error or just crash?
Mar 04, 2014 | Audio Players & Recorders
Lenovo r61 screen
Open the panel on the back and remove the ram. Boot the computer. If the boot code changes then it's probably bad ram. If it's the samew beep code then probably a bad motherboard
Jan 20, 2014 | Lenovo Computers & Internet
The fan don't turn on?
If its a cooling fan, it could be
1-bad fan
2-bad temp sensor
3-bad electrical connection
A check for error codes will give you a start on identifying the source of the problem
Good Luck
Oct 05, 2010 | 1999 Ford Crown Victoria
Can not get voice comands
if you mean like "turn right on Madison" as an example, you must have the tts voice selected ...that is the computer generated voices...it will not work with human voices....
go in the system setting and go to the voice option, and see if you have any TTS voices...if not, they may have been deleted..if so, go HERE and download the web updater and 1st see if there are any updates, then after that it will give you an option to add voices...just select one or some that are TTS...after there loaded to your gps, go back in the voice option and change it to one of the TTS voices.
if you mean you have no sound at all, post back and i will help you further.
bill
Jul 07, 2010 | Garmin nuvi 260W GPS Receiver
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
Voice Navigation
Check your voice prompts.  make sure you are using either Jack or Jane.  the standard voice is the same as the voice on C330 which only gives you directions.
Oct 10, 2007 | Garmin StreetPilot c340 GPS Receiver
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
