Question about Lexmark X3650 Printer
Computer says that the cartridges are in the wrong slots- which they are not. I have tried switching off and on -no effect, same message.Error 1102 The only thing that is different than usul is that I recently installed, newly acquired lexmark colour cartridge No. 33
    Brigadier General:
  • 10,406 Answers
Turn the printer off.
Disconnect the AC power cable from the wall-outlet, to make sure that is "100%-OFF".
Reconnect it.
Remove that #33 cartridge.
Does that get rid of the "wrong" message?
Reinsert that #33 cartridge.
Does that message still appear?
Have you returned the "defective" #33 cartridge to where you bought it, and gotten a replacement for it, and installed that replacement cartridge?
Posted on Apr 14, 2011
Wont recognise cartridges
Try hard reset of printer electronics to restore factory defaults. Also reinstall the driver software and see if it now works fine. If still a no go try setting up printer with another computer. If same thing there then the printer definitely has a nasty issue. If so I do not think a repair would be cost effective.
Sep 23, 2017 | Lexmark Z735 InkJet Printer
Error message says there are two cyan cartridges
I assume you have checked that you have one of each color cartridge, and have them in the proper slots?
Does it say which cartridges are being identified as cyan?
Do you have any spare cartridges?  Even empty ones.  If so, try swapping them out one at a time until the error goes away.  It may be a bad cartridge.
If you're using refilled cartridges, it's also possible they filled the wrong color.
Oct 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
or
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
Finding error messages
Yes ok try and try.
or
Oct 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Dell AIO 962 printer faulty
The error you are referring to could be related to either the cartridge or the printer, so please perform the steps below to check if the issue lies in the printer or the cartridge.
Power on the printer and open the top cove, the cartridges will align in the middle of the printer, remove both the cartridges form their slots and interchange them, yes put the Black cartridge in the Blue slot and the Color cartridge in the Black slot, then close the top cover of the printer and power off the printer and restart it, at this point of time check if the error message is changed or not if the error message is not changed and till showing the same as “Right cartridge is incorrect” then you can try to update the printer firmware form the Dell support site, here is how you can do it.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers.
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
If the issue is still not fixed after you upgraded the firmware then I believe that you will have to replace it. However if the error message changes to Left cartridge incorrect after you have interchanged the cartridges earlier then try these steps below.
  1. Remove the color cartridge and clean the metal contacts of the cartridge with a dry cloth thoroughly please make sure that you are using a soft dry cloth to clean the metal contacts of the cartridge.
  2. Make sure that the cartridge holder snap which sits on the top of the cartridge is fixed firmly.
  3. Make sure that you are using a Dell branded cartridge and it is not a refilled one cause Dell printers often give error message when you use a refilled cartridge or a cartridge of some other brand.
  4. If the issue is still not resolved replace the color cartridge.
Regards
Malik Khan
Jan 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X3650 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
