Question about Whirlpool Microwave Ovens
I have a WMH 1162XVQ2 microwave we bought it in Feb 2010. Today it stopped cooking anything it turns on all looks normal but the food does not warm up. I am not sure if its under warrenty but having it one month over a year ago seems rediculus. I am looking for any trouble shooting ideas or if your willing to pay for repairs. We use our microwave on a daily bases from warming up food to warming baby bottles. So we need help as soon as possiable. thank you for your time on this matter I'd hate to stop being a wirlpool customer. Sincerely, Maureen Webber
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave isn't cooking.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
  • 9 Answers
SOURCE: Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Posted on Apr 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I bought a ge microwave
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: hi i have bought a
Posted on Jul 04, 2008
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
My frigadare microwave runs normal but wont heat the food
From the description you have provided, the magnetron has shorted. This a job for a professional because there is lethal voltages present that will kill.
Mar 27, 2012 | Frigidaire Microwave Ovens
Microwave turns on but wont cook food
It is most likely the magnetron, but! there are two more items that will do the same, a cracked high voltage diode and a shorted high voltage capacitor.
Mar 21, 2012 | Oster Microwave Ovens
I have the black/stainless steel m/v MV8999sb. Just today, when I used the any express cooking button, instead of cooking, it is acting like a kitchen timer. It is also flashing to icons on the top; one...
The two icons are normally present for any timed cooking in this microwave. If you are not getting the food to heat (since express cook is at 100% power), the magnetron, thepart that produces the microwaves, may be damaged. If your unit is out of warranty, it may be easier to replace it.
The part itself is fairly cheap: http://www.partstore.com/SearchResults.aspx?q=Magnetrons&cft=Microwaves+_gt_+Magentrons&cfilt=374&sort=salesrank&ctf=Parts&ctfn=Parts&ps=100&bf=731&bfn=Emerson . However, you need to avoid damaging the seals to avoid having the radiation leak. (It makes the microwave inefficient and can be dangerous to people and pets nearby.) Additional parts for microwaves are also available at partstore.com: http://www.partstore.com/Content/CategoryPages/Kitchen-Microwaves.aspx .
The manual for the MV8999sb is available here: http://kitchen.manualsonline.com/manuals/mfg/emerson/mw8999sb.html . Click the Get this Manual button. See page 13 of the PDF for the pictures appropriate to the Quick Cook option.
I hope this helps.
Jun 06, 2011 | Emerson Microwave Ovens
My over the range microwave will not heat anything anymore. It will turn on but the food does not get cooked or warmed.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 06, 2011 | Whirlpool Microwave Ovens
WMH 1162X VS -1 (watts unknown) Builder purchased
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | Whirlpool WMH1162XV Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
