Question about Syntax OleviaL 527V 27 in. LCD Television
Tv turns off then i turn it on and it stays on
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you may have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
The most relevant one I have made a link for and direct video insert
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
  • Todd Hill
    Todd Hill Mar 27, 2011
    and if no caps looked bulged or puffed where do you go ck ac det. coming from main pcb
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Magnavox about 7-10 years old as soon as i turn it on it turns off and stays off
my 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
Sep 18, 2011 | Proton MM2701VT 27" TV
TV will not stay on. It will turn on and after a
Problem with your TV's picture tube,Replaci it
Feb 15, 2011 | Philips 32PT5441/37 32" TV
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
Jan 24, 2010 | Philips Magnavox 27MT5405 TV
Red Power Light Stays on
Hi, you have a leaky diode, it will not hurt your tv it`s just annoying, my Hitachi has done the same thing for a year and I`m just too lazy to change it out, video-tek
Feb 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Problem to turn on Philips TV
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
Oct 18, 2007 | Philips 27PT563S 27" TV
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Syntax OleviaL 527V 27 in. LCD Television Logo
121 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Jose Pino
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
