Question about Hotpoint Aquarius WMA42 Front Load Washer
Got an error code f-12 washer will not start - Hotpoint Aquarius WMA42 Front Load Washer
    Brigadier General:
  • 6,277 Answers
The decode for Hotpoint (Indesit) 'f12' is 'communications failure', and is often caused by poor contacts between plugs, cables and the control board. It sounds drastic but is as often cured by re-seating (unplugging and re-plugging) the plugs and cables. Sorry but unfortunately this entails an engineer call ;-0(
Sorry again and good luck,
John C
Posted on Mar 25, 2011
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Sep 16, 2015 | Washing Machines
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Error code UL with 12 minutes remaing on each load
hi,
This error code indicates that an unbalanced load is detected.
if the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened.
If Power/Cancel or Pause/Cancel does not work
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start/Pause.
Sep 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Jun 01, 2010 | Whirlpool AWM8143 Front Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
