Question about Husqvarna Chain Saw Models 371, 372xp
My 372xp was in use and started reving up at full rpms and wont kick down. What could i do ?
  • 784 Answers
Check idle settings, if its ok check all valves and carburator assy is ok, check gaskets and sealings.
Posted on Mar 25, 2011
1988 pontiac trans am clutch is slipping
sounds like it needs a new clutch theres no way around it your letting out the clutch fully before it moves at high revs your clutch is burnt out it only works better when its hots because its expanded by the heat but when its cooled down it wont move again yep its a new one.
May 05, 2014 | 1988 Pontiac Firebird
2001 ford expler sport track. Wont go past 2300 RPMs
better take it to a local shop to get a digital readout of errors.....it could be transmission related
Apr 22, 2012 | 2001 Ford Explorer Sport Trac
I have a 1999 Ford Taraus and it starts reving the engine yesterday. It was turning about 2000 rpms while sitting still. Now it has reved down when first started but it will then start revving up and down...
Could be the MAF sensor. I would try scanning for codes, although sometimes the MAF sensor does not show up on scanner. sounds like the MAF to me.
Aug 25, 2011 | 1999 Ford Taurus
Wr250f 2001.riding bike reved and stopped wont kik properly
if this is a two stroke,then if you have run it out of fuel,there is no lubrication for the piston and you may have damaged the piston or piston rings,check the compression,esay test is remove sprk plug pit your finger hard into the hole and crank the bike over,if your finger gets pushed off with loud crack sound then compression should be ok,but if it doesnt and the preesure is very weak then you will be looking at a top end rebuild,hope this helps
Jun 24, 2009 | 2003 Yamaha WR 250 F
The car wont go about 20 miles and hour but the RPMs rev upHELPME
hello,have you a regular maintenance service to your car?better to check your fuel filter for contamination,transmission filter or your brake system maybe stuck-up piston caliper,ty
Apr 16, 2009 | 1993 Mercedes-Benz 190
Engine sputters when load is applied.
check vacuum lines, MAP and MAF to be sure they are correct.
Oct 03, 2008 | 1998 Chevrolet Camaro
Husqvarna Chain Saw Models 371, 372xp Logo
115 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
