Question about Bosch Washing Machines
I have a Classixx 1000 machine which is approximately 7 yrs old. It has developed a fault by which the wash cycles are of random lengths. It can be anything from 3 hours to 20 mins before it moves on to rinse, and now has stopped heating the water so all washing is done in cold water! Please help me!!!
    Brigadier General:
  • 6,277 Answers
It is possible that the heater has been taking longer (and longer) than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever! Worth a try before having to call an engineer! In fact worth a couple of tries ;-0)
Good luck,
John C
Posted on Mar 25, 2011
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Jul 29, 2010 | Bosch Washing Machines
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Not washing
helen going by what you are saying i would say its the program cycle switch needs replacing,adrian
Jan 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
