Question about Thetford Norcold DE0051 Refrigerator
Norcold DR0051 refrigerator freezing drinks on lowest setting. Any setting is full blast -maybe the thermostat is broke? Is there a part that can be replaced? Thanks!
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
  • 110 Answers
SOURCE: Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
Posted on Jun 01, 2008
SOURCE: Avanti Compact Refrigerator Mod.#18ERC/RW
I am about to purchase one of these--Have you found a solution yet??
Posted on Oct 06, 2008
SOURCE: Norcold RV Refrigerator
My Norcold fridge just quit cooling. Still getting power and/or gas. ???
Posted on Oct 26, 2008
SOURCE: Norcold R.V. Frig / freezer not cooling
I have the same problem and I'm not going to pay 500 dollars to get it fixed. That's why i go to these forums.
Posted on Nov 07, 2008
Even on lowest setting, drinks too cold, freezing at back, ice.
Thermostat needs replacing. Can`t find one online but I would guess a standard Danfoss would do it.
Mar 18, 2016 | Whynter Beverage Refrigerator
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
My refrigerator freezes my food and drinks even at lower setting. The freezer is at the lowest setting and freezes my food like rocks.
There is a thermostat inside the casing telling the fridge to keep cooling - forever.
Replace it
Oct 28, 2010 | Refrigerators
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
Freezer over freezes,whats the correct setting?
The thermostat maybe defective. It will not over freeze even at the lowest setting.
May 27, 2009 | Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
hi thanks for your question. i had one with the same problem. and i had to spend $ 500.00 to have it repaired. i think you have the same problem. sorry. the appliance doc
Oct 17, 2008 | Refrigerators
Thetford Norcold DE0051 Refrigerator Logo
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
