Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Powers up, but no sound other than a click through the speakers on power up and turn off.
  • kevin_driver Mar 25, 2011
    Wiring is fine, I triple checked it to the radio and the wiring schematic for the car 3 times. The radio that was removed from the car worked fine but was old radio. The DEH-P2900MP worked fine in my daughters car when it was removed. Is there a mute setting,reset button, or something else maybe?
  • 17,970 Answers
Its possible that you have some problem with the amplifier or bad wire connections; check this wiring guide:
Orange - 12V constant
Red - 12V switched (acc)
Black - Ground
Green - Left Front +
Green/Black - Left Front -
Grey - Right Front +
Grey/Black - Right Front -
Green/red - Left Rear +
Black Green - Left Rear -
Grey/Red - Right Rear +
Black/Grey - Right Rear -
Keep us updated.
Posted on Mar 25, 2011
  • ZJ Limited
    ZJ Limited Mar 26, 2011
    Try disconnecting battery negative that resets my deh5000ub
    In other units work this way... Resetting the microprocessor
    The microprocessor must be reset under the following conditions:
    * Prior to using this unit for the first time after installation
    * If the unit fails to operate properly
    * When strange or incorrect messages appear on the display
    Hope helps.
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
My logitech x240 surround powers on but no sound comes out....what could be the problem??
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | Computers & Internet
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Computers & Internet
Cant get speakers to work
if it is a hardware problem
check to see there is no red X through the speaker this means it Muted if so double click the red X and you will be turning them back on
turn off your computer
1. plug them in most pc's its the green female is the speaker out.
2. do you have power attached to the speakers if you got a power supply or power cord plug, make sure that it is pluged in.
3.turn on your computer.
when you see your desktop see if a speaker is present on the right hand
side of the task bar your in luck
If it is a Software proublem
1.right click on my computer and click on properties.
then click on hardware, then device manager
2.expand sound, video and game controllers the + sign next to the speaker
4. if you notice a yellow exclamation point on sound, video and game
controllers that usually means it's a driver or software
you might need to reinstall the sound cards driver
Mar 15, 2010 | Audio Players & Recorders
Speakers are not making any sounds
ok let's try a simple test.unplug the the usb.i hope that your speaker has its own power supply.turn it on.try to touch the inputs of the speaker, you should hear humming sounds.if yes, then your speaker is ok.if the speaker is getting its power from the USB port, i suggest you should use its independent power.the USB does not have enough to supply your speakers. try also the output jacks for built-in audio of the pc, ok.
May 31, 2009 | Insignia 2.0 Speaker System (2-Piece)
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Yamaha YSP 1100 clicks when press power button but does not turn.
Hi
I have the YSP1000 and I had a similar issue but it was less frequent. I located the clicking sound which turned out to be a relay on the main circuit board. Before replacing it I removed the relay cover and cleaned the contacts. It has not miss behaved since and that was some 8 months ago. Give it a wizz
Mike
Apr 13, 2009 | Yamaha YSP-1100 Digital Sound Projector...
No sound
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
Jul 16, 2008 | Audio Players & Recorders
No sound driver
Turn the power off. Wait about 10 seconds,then power up again get close to the reciever and listen for a click-not from the speakers ,fromthe recievers itself.If you hear a click,you can assume that the power supply is ok for that cercuit.This does'nt eliminate the power supply,but it will do for now.Put the speakers close to the reciever,what you will do now is to power up the reciever while listening to the speakers with the volume off.In about 3-5 seconds you should a hear a slight click from the speakers. Try this with both speakers if you don't plug in a pair of headphones to the headphone jack and play the source . If you still no sound with headphones you at least now know that the output transistors are not the problem or the only problem.The power amp., section are defected also.Message whatever happens.
Jun 17, 2008 | Audio Players & Recorders
Panasonic SC-PT467 Wireless speakers Clicking
I had this exact problem. The clicking is something to do with interference from the power supply cable. It seems that facing the wireless unit in the most obvious way ensures that the power cable and the right speaker cables cross. All I did was turn the unit around so that the wires no longer crossed and magically the clicking sound disappeared forever!!!
Good luck !!
May 28, 2008 | Audio Players & Recorders
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
44 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
