Question about Troy Garden
Lawn mower runs as long as you spray gas into the carbuator , but stops when you stop adding gas.
    Novelist:
  • 111 Answers
There could be water in the carburetor. To check to see if you have water in the carburetor you need to loosen the nut on the bottom of the carburetor (it helps to pinch off the fuel line to keep fuel from coming through the carburetor while you do this) and take off the fuel bowl and see what is in the carburetor. Most of the contents of the fuel bowl will drain out but there should be enough left to see if there is water or dirt mixed in with the fuel. When you take off the carburetor fuel bowl check to see if there is any corrosion on the carburetor. This may have a white, chalky appearance or if it is varnish from old fuel it will look like the carburetor has a "gold" appearance. The correct color of the carburetor is a dull or flat grey. If you find water in the carburetor bowl then there is a good chance that there is also some water in the fuel tank. You will need to drain the contents of the fuel tank. If you want to see what the fuel looks like you can drain it into a paint mixing cup or a clear jar. Start with a clean jar or cup, to make sure that you are seeing what is in the fuel and not what was left in the cup. lol. When you have drained the fuel tank and made sure there is no water in it, I would suggest putting fresh fuel back in the unit. See if the unit will start and run ok. If the unit pops or sputters while the engine is running there may be some more water that will come out after the unit is run for a little while. If the unit continues to not run or is not running very well you may have to clean the carburetor. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal.
Posted on Apr 03, 2011
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Gas sprays out of the carburetor when running
Randy there is a problem with the carb. Stop using the mower until its been repaired. The gaskets need replacing.
Sep 23, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
Primer murray dry
you may need to rebuild the carb
May 20, 2012 | Garden
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Engine does not idle well. always surging.
the nozzle is clogged.if this is a briggs engine it has a plastic carbuator on it.to clean you need to remove the gas tank and carbuator,that the screws out that hold the carb. to gas tank.inside you will find a screen covering the nozzle,carefully using a very small screw driver pop the nozzle from the carbuator.there is an o-ring holding it in.don't lose it.gently blow air both directions through the carb.replace it and start the mower up,surge should be gone now.hope this could help,if not let me know and we can try something else........................
Jun 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
169 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
