My lapto speakers don't work unless i have headphones in
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 25, 2011
No sound without headphones sound with headphones
your device speaker or head phone socket is defective.
Aug 04, 2014 | Computers & Internet
Micro innovation speaker model# MM610D will not turn on
This Is A Huge Problem, Why Don't You Try Reconnecting The
Wires To The System And Run A Reset On It.
Good Luck,
Kevin
Aug 24, 2012 | Micro Innovations MM600D Computer Speakers
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
Till yesterday Seinnheiser rs 110 worked fine when i switched it today only one speaker is working i.e is right speaker.I thought batteries were weak then i recharged but have the same problem.When i tried...
  • The wiring has disconnected inside your headphones. They will not work unless you have someone re-wire the headphones for you. This happens after time with most headphones.
  • Please reply if you have any more questions. Good Luck!
Jul 07, 2011 | Sennheiser RS 110 Consumer Headphones
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
Right side of bose headphone is not working
I have fixed over 500 headphones. Its the plug that connects to audio devices.
Take a look at it http://images.appleinsider.com/ipodiphoneav-review-5.jpg
http://sound.westhost.com/p70-f2.gif
Look at the Standard stereo headphone. When you plug it and unplug it from your audio/music device,
the little 3 or 4 wires disconnect. The smaller the headphone, the more chance this will happen.
To revive your headphone, you have to cut it and re solder the wires to the plug.
follow this step because I don't know how to explain it to you and make you understand it.
http://www.instructables.com/id/Easy-Headphone-Repair-for-Broken-Wires/
Please rate if this helped you.
Apr 19, 2011 | Bose Audio Players & Recorders
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
Can't hear music with headphones when logitech z5 speakers are plugged in.
Hey, you have 3 slot in your soundcard,one is for headphones or speaker, so you have to replace or unplug your speaker from the soundcard and replace it with headphone.you have to choose, not unless your speaker have a slot for your headphone.
Sep 30, 2009 | Audio Players & Recorders
I HAVE A DELL OPTIPLEX 170L WITH BA735 SPEAKERS BUT i HAVE NO SOUND
Make sure you have a sound card installed
    • you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
  1. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  2. Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
If these steps don’t solve the problem, check the information that came with your computer and speakers or go to the manufacturer's website.
Aug 17, 2009 | Audio Players & Recorders
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
