Question about HP VP6111 Multimedia Projector
I have an HP VP6111 projector. It hasn't been used for about 6mths and now I try to power it on and the Blue light around the on/off button will light up for about 3 seconds and then turn off. I've attempted to power cycle the unit (with leaving the power disconnected for at least 1 minute) and it does the same thing. All, steps were done with the projector connected to a laptop (video source) with the laptop setup to output to the projector and the step have been done with it not connected to anything and the results are all the same. Is the unit just shot or might this have something to do with the bulb?
  • 442 Answers
Please do not unplug the power cord before POWER is shut down or during the two-minute cooling process.
If the projector is not properly shut down, to protect the lamp, the system will detect this and cool the lamp for two minutes automatically before turning on again.
Check that you are doing this.
I suspect that this is not your problem though.
It seems that the blue light doesn't flash very long. do any other lights come on during the startup process.
Posted on Mar 26, 2011
HP VP6111 Projector. problem: From day one when I bought it brand new, this projector had problems starting the bulb. Everytime I didn't use the projector for some time, when I tried to turn it on it...
It is a pity you did not return it after the first problem. If it is still under Warranty, I suggest you do now. Even if it is out of time, it is still 'not fit for purpose '
Mar 13, 2014 | HP VP6111 Multimedia Projector
HP VP6111 dlp projector turns on and shuts off inmediately
I think try to check the power supply of the projector and also check if its overheating.
Apr 21, 2011 | Computers & Internet
I can't get an image with dvd or tv with a svtdeo connection
Does the bulb light up at all?? if not it may have a bad bulb,.. can easily happen anytime,.. not just when it is moved,.. check for that
Feb 09, 2010 | HP VP6111 Multimedia Projector
I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
Jan 19, 2010 | HP VP6111 Multimedia Projector
Connected VGA cable to my pc and projector.Searching only
First off be sure that you plug into the input connector. As you look at the back of the projector it the VGA connector on the left. Also make sure you activate the VGA output of you computer (This mainly applies to laptops and secondary Video jacks on PCs).
Jan 15, 2010 | HP VP6111 Multimedia Projector
Dell 1800MP Projector won't power on and no light on button
you will need to replace the power supply. a lot of times, you'll have to remove the spacers on the vga input to remove the projector cover.
Dec 22, 2009 | Dell 1800MP Projector
Hp projector vp6111
Go into the menu and find the lamp timer. You should then be able to reset the timer back to zero.
Nov 19, 2008 | HP VP6121 Multimedia Projector
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
Projector overheating and turns off after 20 mins
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Oct 25, 2006 | Compaq Microportable 2810 Multimedia...
HP VP6111 Multimedia Projector Logo
313 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
