Question about GPS
Garmin Nuvi 750 GPS
My screen says "No Data available and also "Maps locked"
  • 4 more comments
  • snbasket Aug 04, 2008
    I did as you suggested. There was not a file with that exact name.
    There are (3) similiar files. they are gmapbmap.img
    gmapprom.sum
    gmapbmap.sum
    I found that I can get directions from the GPS, although the
    map looks different. It is missing a lot of detail, and When I go for points of interest like
    gas stations, resteraunts, etc. It says there is no data available.
    No, I'm not sure how to do that.
    Do I get that from Garmin's website?
  • snbasket Aug 05, 2008
    I downloaded the update yesterday and no change.
    The data is in the unit, but it is still nota available or locked.When I go to spell out a point of intersest, or choose address, or intersections it says no data available. If I just view the map, It does know where I am at. I also reprogrammed my current location as home and it remembers it and will give me directions there.
    The map that we visually see does not appear as populated.
    Any more thoughts?
    Now I feel stupid. when I had it in my briefcase, the memory card fell out!
    Can I just load the info onto a blank memory card?
  • snbasket Aug 06, 2008
    I'm still not done.
    I can not find the old memory card.
    I have a new blank card.
    What do I need to load onto it?
    And how?
  • Anonymous Aug 20, 2008
    pls send me original folder gps
  • 298 Answers
Have you tried this?
You can try this step that I found. If you tried loading other mapas try this.
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Posted on Aug 03, 2008
  • 4 more comments
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Aug 04, 2008
    have you tried to reinstall the map or reloading it?
  • Jeffrey Pedimonte
    let me check that.
  • Jeffrey Pedimonte
    there is an update in garmin's dowload page. the map that you are using is that the map that on the sd card or is that a map that youd downloaded.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Aug 05, 2008
    We need to further isolate the problem that you have its either a problem with the man or the unit. Now since the update did not do anything and based on how the unit respond to the test that you did it remembers the setting the location where your are. Its just having troubles showing your point of interest. What I suggest you try right now is to reload the map on your memory card.
  • Jeffrey Pedimonte
    if you still have the same memory card that you were using before you can insert it back to the memory card slot but if you dont you can reload the map on to a blank memory card.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Aug 06, 2008
    Your comes with a CD or a DVD you check if it contains the map you can just copy it from there to your blank memory card. Now if does not have one then you can download it from garmin's website. But I suggest you check first the cd or the dvd that came with your unit if it has a copy of the map.
    One more question the original memory card was it already loaded with the map?
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 750 went dead when i got it to
Hello :
Resetting your GPS could solve the problem .
Here is how to reset your NUVI :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 750 GPS Receiver
Well my Garmin nuvi 1300 was working fine yestarday but now it's saying "No Map Data Available"... What does that mean?
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
Oct 24, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 750 won't say street names after upgrade to 2009 maps
User's manual available at www.garmin.com. Select "support", then "Manuals". Enter "mobile electronics"+"automotive"+"model #". Manual says that selecting a language with a person's name will speak street names.
Jul 04, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin750 usb'd to PC. all i get is log with connect pic
When you connect the 750 to a computer it goes into data mode and the screen shows only the connected to PC icon. Let it charge for a few hours and then disconnect it from your computer and it will come up in Navigation mode,
May 17, 2009 | Garmin nuvi 750 GPS Receiver
Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Jun 17, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
1,047 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
