Question about NetGear DGN2000-100NAS Router
My new (refurbished) Netgear DGN2000 router/modem refuses to establish a broadband connection. It's fine as a router but whether I let the so-called Setup Wizard make the connection, or I try to set it up manually, it always reaches the same conclusion: LCP down. I've triple-checked my login name and password (with Plusnet), and everything else (IP and DNS addresses etc) is as it should be. Why is the modem not connecting?
5 Suggested Answers
  • 117 Answers
SOURCE: My Netgear DGN2000 keep coming with frequent
please follow steps to resolved your issue
1.upgrade firmware on router
link for letest firmware
http://kb.netgear.com/app/products/model/a_id/2334
2 make sure that login detail is correct(from isp)
after all this i am sure your issue would be fix
Regards
prakash
Posted on Mar 21, 2010
SOURCE: Problem connecting Ipod touch to WiFi
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
anandg27
  • 1272 Answers
SOURCE: Have a new Hughes net HN9000 satellite service and
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Posted on Jun 30, 2009
  • 150 Answers
SOURCE: I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Posted on Aug 30, 2009
Testimonial: "I received great help! I got speedy replies and great information at a level I could always understand and proceed to work with. Great first experienc"
Not able to browse the sites using Netgear DGN2000 router...
May be good to disable all additional settings. e.g. firewall or Port forwarding. I am assuming that you are able to authenticate (connect with user id + password) as you mentioned youtube works fine. So in that case, there shouldnt be a basic issue but more of a port forwarding or nat. Also check your laptop for any setting changes or personal firewalls.
Try pinging local gateway, then DNS then any international website. Based on that you can focus on the problematic area.
Apr 07, 2014 | NetGear DGN2000-100NAS Router
Sky anytime+
Call Sky - the guys on the help line have a code which takes you to an advanced menu where your broadband can be setup properly for your router. It sounds as though the box and router are conflicting - happened to me :'
Apr 30, 2012 | NetGear DGN2000-100NAS Router
When i connect my netgear DGN2000 to the dsl and ethernet, i still can't access the internet, what can i do to fix this?
Router set up
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | NetGear DGN2000-100NAS Router
LAN connections dropped
Well, this make of the router DGN2000 has been diagnosed with hardware failure. I would suggest you to contact NETGEAR and get a replacement from them.
You can log a complaint with them at my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Feb 17, 2010 | NetGear DGN2000-100NAS Router
When I change modems i can't connect to the internet.
You must provide valid wan configuration on the modem part. Get it configured from your providor or check your old modem configuration note down wan settings. Apply these settings to your new ADSL+Router.
Jul 15, 2009 | Computers & Internet
Cannot establish broadband connection from cd
Try downloading drivers for the device. Google is youre friend :]
May 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
NetGear DGN2000-100NAS Router Logo
85 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
