Question about KitchenAid Dishwashers
There is an awfull smell after washing a load of dishes and the smell seems to stay. this has been going on for at least 2 weeks. what can be causing this and what can i do
  • 822 Answers
Sounds like the pipes inside the d/w are clogged up with ****. you need a good d/w cleaner to flush it out........... run d/w without any pots in it................(empty)......... may just help..........
cheers
Posted on Mar 25, 2011
Clothes smell after being washed, seems like it is water that stays in the pump causing the clothes to smell
In Europe, they have had these same machines for decades. The shortest load possible you can run is one hour 30 minutes. This is for dark loads on cold water. I think in America we have tried to do things too fast once again, with the mentality that "faster is better". Such a little amount of water in such a short time with thick fabrics like towels, jeans, etc. makes it, in my opinion, impossible for anything come out clean. I now do ALL my laundry on the longest setting available and this seems to help; however, the "efficiency" part of the sales pitch has pretty much been "a wash." :-)
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell on dried dishes after being washed.Stale water smell.
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell
Try running washer empty with soap or tablet in the regular cup and baking soda in the secondary cup. After cycle is complete and somewhat dry inside leave slightly open to allow air circulation overnight. This should help.
Sep 15, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washer
Bacteria causes odors. Try running a load without any clothes on HOT and add a cup of bleach to the soap dispenser. In the future use the hottest water the care tag on your clothes will allow. Use bleach as often as possible. If it's a front load washer, make sure you are using HE detergent. Non HE detergent will suds up and the suds could potentially remain after the wash and create an odor. If you don't like to use the hot wash or bleach on your clothes, then you may need to run a load once a month as described above. There is also a slight chance it's coming up from the home plumbing. Make sure the home plumbing is draining fast enough, but ultimately the bleach you use in the washer will run down the drain and help keep it from causing an odor.
Jul 21, 2008 | GE WSXH208A Front Load Washer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Dishwashers Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
