Question about LG RHT397H DVD Recorder
Have a LG RH 387 DVD Recorder, and struggling to use the timer record. It gives me a mesage which says" Try channel setup first " I,m running my recorder through my Marantz H fi , and my Satelite decoder plus TV. Normal recording and viewing is 100% but i cant do timer recording. Is my connections wrong?
SOURCE: dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Posted on May 02, 2009
  • 98 Answers
SOURCE: dvd/vcr recorder stops recording
I finally got word back from a pal at LG regarding this issue as where I work we are getting these and as of Friday had about 18 to 20 units with this issue.
LG told us that this has to do with the encoding with the commercials (a one time record issue) on the one time record disks (DVD-R and DVD+R) now their "TEMP" fix for this is to used DVD-RAM or DVD-RW disks (these are not regular -RW they have a encoding CPMsomething I don't remember right now) but they will update us when they have a permanent solution. I will get the type of disk for the -RW on monday and post it here for everyone.
Posted on Nov 09, 2008
SOURCE: LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Posted on Mar 18, 2009
vortash
  • 431 Answers
SOURCE: LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
Posted on May 12, 2009
vortash
  • 431 Answers
SOURCE: eject dvd doesn'start recording
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
Unable to tune channels
Hi Andrea
Try install attenna prior doing some auto programming.
Jan 27, 2014 | LG RH1999H DVD Recorder/HDD Recorder
How to set up LG RH 387H HDD/DVD recorder for recording fron T.V
First, please note that your LG 387H is capable only of tuning analog channels, not the digital ones...
The easiest way is to connect your recorder directly to your incoming cable, then connect the output of your recorder to the TV set. Depending on what your set has available, either connect the HDMI OUT to HDMI IN on your set (best picture), or the A/V OUT to your sets A/V IN. Leave your set on the input you have selected, and use your recorder to change channels.
Jan 30, 2011 | LG Televison & Video
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
May 12, 2009 | LG RH266 Recorder
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
DEAR SIR my LG rh-2252 dvd recorder has problem.it turn on,but just show in display box:hello and a few minute later :please wait please wait please waite. but it does nt work.no voice,no picture
some dvd recorders take a while to come on if you turn it on with no disc in and wait for it to load up also check that the cables are all in correctly and you are on the correct channel it should show a start up screen also try changing the channel through the dvd recorder if this does not work and you have read through the manual contact the manufacturer or supplier
Nov 29, 2008 | Televison & Video
Can I make my LG RH4820W HDD/DVD recorder multi region?
1 Power on the DVD recorder
2 Press "open"
3 Press "0000000" on the remote control slowly
4 Congratulations' will display on the screen if setup was successful.
5 Press "enter", then finish
Nov 19, 2008 | LG RH-4820 DVD Recorder
Code region
1 Use the remote
2 Press HOME
3 Move to SETUP
2 Scroll down to LOCK (no need to enter LOCK options)
3 Press '0' seven times
A message that confirms that the player is region free will appear on the screen
hope it helps!
Nov 16, 2008 | LG RH266 Recorder
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
DVD Burning doesn't work..no Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Jan 22, 2008 | LG RH-4820 DVD Recorder
LG RHT397H DVD Recorder Logo
255 people viewed this question
