Hotpoint wf740. the seal around the door has become twised and an error code F-12 is showing, please help !!!!
    Brigadier General:
  • 6,277 Answers
Hotpoint (Indesit) 'F12' decodes as 'communications error' which sounds rather drastic but often can be cured by having plugs and cables reseated (removed and replaced) on the control board- an engineer task ;-0(
It may be possible to have the door seal repositioned rather than replaced at the same time.
Sorry I can be no more help than this ;-0)
Good luck, John C
Posted on Mar 25, 2011
I have a hotpoint wf740 which has had a bad smell coming from it, i took the front off the bottom, and unscrewed the filter which then snapped when i pulled it off as it was full of coins. (my dad gave me...
I think this is your pump and filter.
http://cgi.ebay.co.uk/hotpoint-indesit-drain-pump-and-filter-assy-new-sealed-/220605267643?cmd=ViewItem&pt=UK_Home_Garden_Washing_Machines_Dryers_Parts_Accessories_ET&hash=item335d193ebb
I spent a very long time looking for this. I recommend you look in your local phone book business pages for Appliance parts / supply and have your model number WF740 in hand. These complete pump assys appear to be cheaper than just the filter. You can order the new pump / filter assy and just use the filter for now.
Thanks for using FixYa,
Kelly
May 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius+ wf740 clicks to start a program then after a while it says ''door'' on control panel tried slamming it still not working
Try fitting new door handle, and or spring, failing that, then fit door lock.
Thanks.
Mar 29, 2009 | Washing Machines
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hot point aquarius wf740
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Jun 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
