The unit runs constantly but no water is collected. I've cleaned the cooling fins, etc, but no help. What next?? It has been this way since I purchased it.
    Master:
  • 403 Answers
What is the unit, no info given.
Posted on Mar 25, 2011
We need the manual for this air conditioner. We have a lot of condensation coming from the internal unit after we switch it off from the cold setting.
there will always be condensation on the fins of the indoor unit as that is the purpose of it
The evaporator condenses the hot moisture of the air in the room as it hits the cold evaporator fins and that water is drained off by a hose to the outside of the house
One way to reduce the condensation to a minimum is to keep the fins clean of the greasy dust that collects as that way the water is running while it is operating and not collecting in the fins
Jan 25, 2016 | Heating & Cooling
AC Starts normally but after some time of coolinf compressor in outdoor unit trips. Compressor running light in indoor unit remains on and outdoor unit fan remains on. But no cooling. After a break of...
Probably overheating. Check the outdoor coil and see if it is stopped up with dust, grass etc. If so, disconnect power to the unit, and clean the condenser coil with water or air. Be careful not to bend the fins if you use a water sprayer.
Apr 11, 2011 | LG Heating & Cooling
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
My dehumidifier has not, does not collect any water. HELP !
Take care.
Aug 10, 2010 | Amcor AHD45 Dehumidifier
I have a 5th whell RV Couger 2006 had 1 AC unit replaced already now two years later it only pumps slightly cooler air but has condinsation streaming off the roof. An hour and a half later the interior is...
Yes it is a sealed unit, and there are some refrigeration guys who can solder on valves and recharge, but make sure you get a quote first, as some charge as much as a new unit. That said, I'd be looking at evaporator coils/fins as well as condenser coils and fins for dirt and debris and give them a real good cleaning. I'm going to assume this is a ducted ceiling, so Make sure your getting flow through all those ducts, and check for how cool it is. Does it feel like cooler air coming out the ducts? Rule of thumb is 20 F difference between ambient and discharge should be normal. All that condensation tells me it's trying to cool but you may have a problem elsewhere, like plugged fins, or faulty ducting. If the flow coming out of ceiling ducts is not good and cool, try removing the ceiling assy and see if the discharge side is cool there, and check that the ducts in to the ceiling have no obstructions as well and are properly aligned.Let me know what you find. Make sure return air filter is clean as well and get a flashlight and look way up in the return area, at the fins for dust collected on fins etc. If you remove outside cover on roof, turn off breaker, and you can use a hose to spray down and a nylon brush to clean fins and coils at condenser. Watch for bees, or wasps when you remove that cover on the roof.
Jul 28, 2010 | Dometic Rooftop RV Air Conditioner
Dehumidifier runs but does not collect water
you must also clean the fins on the front. remove the plastic case and use compressed air or coil cleaner to clean out the dust and dirt on the condenser coils. if there is not enough air flow, the freon will not cool enough.
Jul 23, 2009 | Edison DHE55 Dehumidifier
Runs but does not collect water. Humidity is not going down.
It is possible that the cooling fins are not working due to insufficient coolant or the compressor system is faulty. Basically the fan pulls air across a cooling fin . Moisture from the air then condensates and falls into the pan as water. The air is then heated before it exits into the surroundings. The fact that there is no water collecting suggests that the cooling stage is not working. I see from other posts that there is a fuse somewhere. Maybe this fuse is blown and is associated with the cooling compressor..hope this helps
Jul 19, 2009 | Haier HDN655E Dehumidifier
Unit works fan runs lights turn on but no water in the bucket,
Some units use the condensate water to cool down the condenser coil. This is why no water is present. If water is leaking from the unit or you are still sceptical about this problem, I would call for service.
Mat
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Cooling fan running constantly.
the cooling fins are clogged, u need to get a small vacum and clean the area
May 09, 2009 | Computers & Internet
Dehumidifier
if the fins feel cold then you should be collecting condensate. so try this: remove the outer shell to access the fins. with a garden hose, spray the fins off thoroughly. you may see a lot of dust and line that was clogging the air flow.
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
