Question about Acer Audio Players & Recorders
My laptop speakers don't work unless i plug in headphones and i checked all the sound settings!!!
  • Acer Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 25, 2011
My laptop plays sound out of both my speakers and headphones.
It sounds like that port is set to mono, go to properties and check that.
Jan 10, 2015 | HP Pavilion Computers & Internet
Headphone jack not working on dell d810
andys_cars,
You may need to go into the sound properties and then to deviceto change the settings to enable the speakers and change it from headphones to speakers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 04, 2013 | Dell Latitude D810 PC Notebook
The sound has stopped working on our GeoSafari LAPTOP No. 8545. Help!
Hi Lisa,
What operating system are you using?
Check that sound is enabled in both the operating system and BIOS.
Check that you have the volume turned up.
If you have an external set of speakers, try plugging them in and see if you get sound. If the external speakers use a power supply, make sure you have the speakers powered and turned on. Computer speakers almost always require power to run the internal amplifier. Computers sound output is so low that regular speakers can not be used. Also, if you have a set of headphones from an iPod or similar device try the headphones. Headphones are sensitive enough to work without power.
Aug 06, 2012 | Computers & Internet
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I HAVE A DELL OPTIPLEX 170L WITH BA735 SPEAKERS BUT i HAVE NO SOUND
Make sure you have a sound card installed
    • you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
  1. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  2. Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
If these steps don’t solve the problem, check the information that came with your computer and speakers or go to the manufacturer's website.
Aug 17, 2009 | Audio Players & Recorders
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
My sound is not working unless i use headphones.
You need to check if internal speakers connection / cable is hooked up properly. You may need to open up the pc to see. If help needed on this, please as a technician to assist if you're not comfortable enough in opening it up alll by yourself.
If the connection or the internal speakers is busted, parts may need replacement.
Jan 06, 2009 | HP Compaq Presario CQ50-211NR Notebook
Dell 610 lptop - haedphone not working,
First try uninstalling the sound drivers from the device manager, then reboot. It will find and reinstall them, then check Dell's support site for updated sound drivers. If you find updated drivers you will need to use the update button for the device in the device manager. If this doesn't work, then it may be a faulty headphone jack. The jack should override the speakers when the headphones are plugged into it. If you can still hear the speakers with the headphones plugged in then the jack is faulty and needs replaced. If the jack does override the speakers or if you get some static then it could be that the jack has come loose or has a loose or broken wire. The only other thing is try a different set of headphones, sometimes laptops get picky and one set will work and yet another set may not.
Jul 02, 2008 | Dell Inspiron 2200 Notebook
Odd Sound Problem...
sounds like headphone plug in is bad sorry no way to fix this unless you reinstall new head phone plug in .. lala linda
Jun 07, 2008 | Acer Aspire 3680 Laptop
56 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
