Question about LG Washing Machines
My LG Fuzzy Logic 6.5KG WFS65A01DCT - The wash and spin lights are blinking with a pulsing sound, even the lid is closed..what do i do?
    Brigadier General:
  • 6,277 Answers
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
3 Suggested Answers
SOURCE: My LG Fuzzy Logic 6.5KG
I had this exact problem just now. There is supposed to be a small magnet located at the front of the lid that meets up roughly above the 'fuzzy' light when the lid is closed. My washer was missing this magnet. I modified a fridge magnet and glued in in place. The washer now works. :)
Note: You will need a magnet strong enough to operate the switch, turn on the machine and put it on a cycle, hold a magnet near the fuzzy light where the door would close to test if the machine works.
Posted on Jul 04, 2011
SOURCE: My LG Fuzzy Logic 6.5KG WFS65A01DCT - The wash and
My LG washing machine WFS65A01DCT shuts off with the error signal that the door is open when it's not. How do I disable that signal?
Posted on Dec 19, 2010
On my fuzzy logic 6.5 top load I keep getting a beep and the wash and spin indicators blinking simulatinously. What could be the reason for this, how can I fix this?
I had the same problem. I lost the magnet in the lid cover. So, I put a magnet as shown in the picture (blue and red color one). It working now!!!!
May 24, 2014 | LG WM-2077C Front Load Washer
Lg fuzzy logic
check your lid and out of balance switches.
Nov 08, 2013 | Washing Machines
Do you have a user manual for a Fuzzy Logic 6.5kg top loader washing machine WFS65A01DCT
copy and paste the serial number(WFS65A01DCT)onto your address bar and this will take you to the site that you can download the user manual for your machine.
Jan 17, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG Fuzzy Logic 6.5KG WFS65A01DCT - TThe wash and spin lights are blinking with a pulsing sound, even the lid is closed..what do i do
Jun 06, 2011 | Washing Machines
My LG Fuzzy Logic 6.5KG WFS65A01DCT - The wash and spin lights are blinking with a pulsing sound what do i do?
Feb 13, 2010 | LG Washing Machines
I have a LG Fuzzy Logic washer model WF-T1050TP, AND IT STOPS RUNNING SAYING THE LID IS NOT CLOSED SAYING ERROR d3, BUT THE LID IS CLOSED???
the door switch sounds like it has gone bad, check with a multi meter, they can check it for u at any appliance parts store if u dont have a multi meter
Jul 04, 2009 | LG Washing Machines
LG Fuzzy Logic won't spin
I had the same problem with my machine. so i just jammed the sensor that deactivates the machine when it starts spinning wildly. doing this allows the machine to work it just sounds like its going to blow up for the first two or three spins and then it sorts itself out.
Dec 04, 2008 | Washing Machines
LG Fuzzy Logic
Place a piece of magnetic material at the edge of the lid, for the wf-s6697tc model.
Standing in front of the washer, it is slightly off centre to the right (at the edge where the lid covers, space between the wording speedy soak & fuzzy). If you pay attention to the lid, you might notice some brownish rust stain.
This is where they place the magnet.
Feb 01, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
399 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
