Question about Mercury P4VM800M7 Motherboard
My computer started crashing and I could not use reset or switch on front of computer. I had to disconnect the power. wait 10 seconds then turn on power and restart. when computer crashed the fans were still working but I think hard drives were stopped. Now computer has no response and will not start, Any help will be appreciated. Thank you for you time Denis.
  • Mercury Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Posted on Mar 25, 2011
Lenovo idea pad 300 won't turn on. Red power light blinks 3times then switches off. Rebooting doesn't work. Tried different adapter. Power on Lenovo screen appears for 5 seconds then goes black.
Sometimes they 'crash' in sleep mode. Try hold the power button down for 10 seconds. This should make it reset. After the 10 seconds, release the power button. Then press it again to turn it on normally.
Oct 09, 2017 | Lenovo Computers & Internet
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
Error 0xd05d010d reset power
reset the printer follow this steps
  • Turn the printer off with the front panel button
  • Disconnect the power cord from the product, and then wait 20 seconds.
  • Press and hold # and 6 while reconnecting the power cord.
  • Wait 10 seconds, and then release both buttons. The product resets and prints an alignment pag
Jan 22, 2014 | HP Officejet 5610 All-In-One InkJet...
HOW DO I RESET A SMC 10/100 TO FACTORY DEFULT
Remove the power cord from the back of the switch.
Remove all cables from the front panel ports.
Connect port 1 to port 2 on the front panel using a standard patch cable.
Reconnect power to the switch.
Wait at least 40 seconds before disconnecting the patch cable between port 1 and port 2.
After the above is completed, the password will be "smcadmin" and the switch IP will revert to 192.168.2.10
Mar 01, 2013 | SMC Tigerswitch 24-port 10/100 Switch...
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
How reset officejet 8500
  • Wait 10 seconds, and then release both buttons. The product resets and prints an alignment page.
If this does not work, repeat the same process and hold 9 instead of 6
May 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
MY MAC G5 IS NOT BOOTING . WHEN I PUSH THE POWER ON SWITCH THERE IS A BEEP TYPE SOUND AFTER FEW SECONDS AND THEN SPEEDY FANS NOISE IS HEARD.AND INSIDE I SEE RED LIGHT GLOWING
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Times; color: #1a1a18} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Helvetica; color: #1a1a18} span.s1 {color: #0066a4} span.Apple-tab-span {white-space:pre}
Power-on LED illuminates when power button is pressed, fans spin, and boot tone chimes, but there is no video
1. Reseat video card. (Make sure video card is fully inserted in connector and end of card is secured by the connector latch.)
2. Reset PRAM (restart computer while holding down Command-Option-P-R keys until second boot tone chimes)
3. Replace video card
4. Reset logic board. Refer to "Resetting the PMU on the Logic Board" in this chapter.
5. Replace logic board
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 14.0px Times; color: #1a1a18} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Helvetica; color: #1a1a18} span.s1 {color: #0066a4} span.Apple-tab-span {white-space:pre}
The PMU (Power Management Unit) is a microcontroller chip that controls all power functions for this computer. The PMU is a computer within a computer. Its function is to:
tell the computer to turn on, turn off, sleep, wake, idle, etc.
manage system resets from various commands.
maintain parameter RAM (PRAM).
manage the real-time clock.
Important: Be very careful when handling the logic board. The PMU is very sensitive and touching the circuitry on the logic board can cause the PMU to crash. If the PMU crashes and is not reset, the battery life goes from about five years to about two days.
1. Disconnect the power cord and check the battery in the battery holder. The battery should read 3.3 to 3.7 volts. If the battery is bad, replace it, wait ten seconds, and then proceed to step 2. If the battery is good, go directly to step 2.
2. Press the PMU reset button once and then proceed to step 3. Do not press the PMU reset button a second time because it could crash the PMU chip.
3. Wait ten seconds before connecting the power cord and powering on the computer. If the computer does not power on, there is something else wrong with it; refer to the "Startup Failures" section of "Symptom Charts" in this chapter.
Note: The above procedure resets the computer's PRAM. After resetting the PMU, be sure to reset the time, date, and other system parameter settings.
Dec 11, 2010 | Apple Power Mac G5 Desktop
Getting error code C11A4 can you help me fix this please?
Some basic reset procedures.
A. Open and close the front door.
B. Power off the machine, wait 30 seconds power on.
C. Power down the machine, unplug from the wall for 1 minute, plug in and power on.
D. 13.1 Trouble resetting
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than 10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
Nov 19, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Mercury P4VM800M7 Motherboard Logo
37 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
