Question about Ovens
I have salva rotery oven if i start after one mument make alarm cod (AL 1) model my oven (MG - 11 - E / 00) Electric thank you
Hola me hace falat el manual de salva sirocco sm 11 manual de uso y esquemas electricos
Numeros de telefono y correo electronico para llamarlos o escribirlos en el internet para el manual en su pais.
Nicolas Uranga
Tel: (+56)9 923 83 690
email: nicolas.uranga@salvagroup.net
Creo que ese numero de telefeno esta en Chile.
Donde esta usted? Hay numeros para espana y america del sur (Uruguay, Chile, etc.)
http://pdf.archiexpo.com/pdf/salva/sirocco-ovens/66345-292667.html#search-en-salva-sirocco-sm11-oven
Mar 31, 2018 | Ovens
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
Highest temperature during self clean mode?
different brands, different models, different temps. they al range from 900 degrees up to 1300 degrees.
Apr 06, 2014 | Thermador SC302T Electric Double Oven
Ihave a minder shed alarm (4 button model) the batteries ran out and i dont know how to reset it any1 help!
Factory Code settings 1234, To change the factory code press button 1 for 2 seconds, wait for 2 beeps, now enter your new 4 digit code, you will hear a further 2 beeps to confirm the new code. If the battery is removed the code will revert to the preset code(1234)
Nov 05, 2011 | Stoves 720EF Electric Double Oven
My ST 92 Salva Oven displays fault code AL 3 what does it mean
my salva st-92 oven is displaying AL9 fault code
May 05, 2010 | Ovens
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Need to know how to use the timer
The manual for this Oven is available free to download at http://www.safemanuals.com Regards Vortash
Apr 28, 2009 | AEG B3101-4 Electric Single Oven
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
