Question about Harman Kardon AVR 635 Receiver
How to connect sub whoofer, can see outlet on console for sub wich is a single connection but on sub its self has 2 ports
    Problem Solver:
  • 11 Answers
You can get an RCA splitter; or just use one of the 2 sub inputs on the sub amp.
Posted on Mar 25, 2011
2 ohm amp to 2 10 inch dual coil 4 ohm subs how does it need to be wired
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Apr 08, 2016 | Dual Car Audio & Video
Wgy does my cd player only have one sub outlet rca?
Some dvd head units only provide a single mono RCA output for sub woofers. Not to worry. Buy a Y-Splitter RCA cable (1 Male to 2 Female) Now connect your normal RCA cable to that as you would do with any other unit.
dreamsystems
Feb 16, 2011 | Jensen Car Audio & Video
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Apr 04, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Wiring
hi!well i think you should use both channels.because if you'll use both channels then u'll have high power to your subs.i have tryed it and i prefer you use both channels.
Jun 26, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Harman Kardon AVR 635 Receiver Logo
110 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
