Spooling subsystem error. I can print some things but some things get stuck and I cannot even delete them.
    Guru:
  • 610 Answers
Click "start" and go to "Run"
Type "services.msc" at the prompt which will open the Services
window.
Scroll down the alphabetical list in the right window pane until you come
to the entry with the name "Print Spooler"
Right-click this entry, then select "stop". This will stop the computer
running the process that holds your print queues.
Leaving that window open for now, click again on "Start", and then click
"My Computer" to open a Windows Explorer window.
We've stopped the queue service, now we just have to clear the jam that is already there. To do this we navigate to the print spool folder which is hiding within the Windows folders. Usually Windows is installed on C: drive, but you should be able to tell when the Explorer window opens which drive it is on.
The usual path to the spool folder is C:\WINDOWS\system32\spool\PRINTERS, but yours may be slightly different. Your windows drive may have another name for instance, but this would be uncommon. So click on your Windows drive (usually C), then double-click on the Windows folder, and then find the System32 folder and double-click on that. Windows may warn you that you are about to view system files, but click "View files anyway" message and search out the "spool folder". Within the Spool folder is your Printers folder, and you should open that.
Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just hit "delete").
Close the explorer window now that we have emptied the cleared spool files and return to your Services window. We must re-start the Printer spooler service, and do so by right-clicking the Print Spooler entry and selecting "Start" from the list. Close the services window and try printing again.
Posted on Mar 25, 2011
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
Tip
Troubleshooting Printer Spooling Problems
At its most basic definition a printer spooler retrieves the data for a requested print task and performs the required print even if it is not printing multiple print jobs. The simplest explanation, and where you should start, is in the task manager. Under "processes" in the task manager look for a file called spoolso.exe or spoolsv.exe; if these files are not present it simply means that the process has been stopped and needs to be restarted. This can be done by running "net start spooler" command. In the start menu bring click on the "run" option and type the command in the box prompt. Sometimes a faulty printer driver is the cause. This is hard to determine in any sort of certainty, but a simple reinstallation of the drives is simple and easy enough for virtually any user. Uninstall and reinstall your printer driver; if the printer works after the reinstallation you are safe and ready to print. The next step would be to check if old printer drivers are still installed on the computer. These can sometimes conflict with each other allowing an old print driver to be the spooler and not the proper driver for the current printer. Remember to clear the printer's queue before removing the old drivers. A last attempt at solving printer spooler problems is to manually delete the files in the printer driver. These will all be either .shd or .spl file types and are located in the temporary directories of your printer spooler subsystem. Whatever you do, do not delete the spooler subsystem app. This can cause even worse printer problems and in rare cases can cause major printer failures and errors. Should none of these work or solve the problem, it is in your best interest to seek a professional in the matter of solving the problem. Most printer spooler problems can be solved by the user in a few short steps.
on Sep 28, 2010 | Office Equipment & Supplies
My HP Photosmart C4280 stopped printing documents.
it stopped printing and saysthat something is wrong some spooler error
May 03, 2010 | HP Photosmart C4280 All-in-One InkJet...
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Won't print. Red light blinking
Reboot your computer and power down your printer. Leave them off for about 30 minutes or even overnight. (In other words, leave the computer and printer off more than a few minutes--some of the printers take more than 5 minutes before they'll clear their memories--a quick reboot won't do it.)
When deleting print copies it is safer to use the delete button on the printer than to delete from your computer, as then the copies don't get hung up in spooling.
I've had to do this a few times with Vista and printers, as things get held up in spooling on a regular basis.
Jan 05, 2009 | Brother HL 1440 Laser Printer
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Caught in spool, can not cancel or print
Been working on my computer for two hours on this problem!
i could not cancel what was in the spool
do this
If you are on Vista Home Premium, go through the following steps to clear "deleted" print jobs from the print queue.
1) Go to Control Panel
2) Select System and Maintenance
3) Select Administrative Tools
4) Double-click on Services
5) In the list of services, scroll down until you find one called "Print Spooler"
6) Right-click on "Print Spooler" and select "Restart"
7) The "deleted" jobs will disappear and any queued jobs in your print queue will print
Hope this helps. I figured it out on my own without any assistance from the paid professionals
Sep 09, 2007 | Lexmark X4270 All-in-One Multifunction...
Deleting-S error HELP
Try to stop and restart the print spooler (right click on My Computer and then select Manage. At the bottom of the Computer Management window, expand Services and Applications. Click on Services, and on the right side of the window look for Print Spooler. Right click on it and select restart). Even if this procedure does not fix your OADP file problem, consider it in the future and avoid restarting the computer every time you want to get rid of spooling printing documents.
Jul 25, 2007 | HP DeskJet 1280 InkJet Printer
Computers & Internet Logo
102 people viewed this question
Alun Cox
David Payne
David Payne
