Question about Sherwood RX-5502 Receiver
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the Subwoofer only has RCA outputs and inputs. Should I try to use the headphone output and splice a headphone cord (by altering the other end to RCAs) to plug into the subwoofer's inputs? Any other suggestions for incorporating the subwoofer?
    Brigadier General:
  • 8,546 Answers
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Posted on Mar 25, 2011
Model rv6030r. How can I connect a subwoofer?
On those older model receivers there is no place to connect a subwoofer, you need to get some high quality 3 way floor speakers and use those, the crossover network in the speaker takes care of the routing of the low end signals to the woofer.
Feb 13, 2016 | Sherwood Audio Players & Recorders
Schematics rx5502 sherwood
All you can do is search the Internet for such a service manual. I find them at Hi Fi Engine or Electro Tanya on occasion. Stereomanuals dot come will have good paper manuals but they are not free.
Jan 29, 2014 | Pioneer Audio Players & Recorders
I have a Jensen KS212 and I'm connecting it to a home theatre receiver direct to see if it works but nothing comes out of it. Does this mean the sub is not working or there's not enough power from...
Hi, welcome to FixYa..
Your subwoofer requires a seperate amplifier that has low pass filter in the pre out system, which means it will allow all low frequency signals from the input section of the amplifier/ crossover. Your receiver has combined signals of high, mid and midbass signals that will not be able to drive your subwoofer. That is the main reason why some receivers has "Subwoofer Out" to allow you to use "Active Subwoofer systems" (also known has self powered or has a built in amplifier w/ subwoofer)
For you to use your Subwoofer, it must have a seperate amplifier, connect it to Sub out of your receiver and from there you can hear the difference. Hope this helps.
Jul 13, 2011 | Jensen KS-212 Car Subwoofer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
Sherwood RD7502
Hi - You can download the manual by clicking the link underlined in blue below:
RD-6108
Your sub woofer needs to have it's own power amp i.e. a "powered" sub woofer:
Assuming your sub woofer is powered & connect as shown then check the following setting:
Let us know how you get on.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 06, 2008 | Sherwood RD-6108 Receiver
Sherwood RX-5502 Receiver Logo
502 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
