The problem that I am having with my Emerson PL-P42W-10A plasma tv is that allof a sudden it would not turned on one morning. When you turn it on the tv clicks like it is coming on then you get three blinks of the power on light before it clicks of about 15 seconds later.
  • hazlaw7 Mar 26, 2011
    Thank you for responding to my post. I have replaced the y sus. and y buffer boards because that was the diagnosis that I recieved from a TV service center in my area. After replacing the parts the tv did the exact same thing. When you turn it on it blinks 5 times then goes out then blinks twice right before it clicks off about 15 seconds later. I am thinking that I need to replace the power supply board and test it with the original y sus. and y buffer boards to see if that works. Then hopefully I can recoup some of the money spent on the two boards i tried already. Earlier I forgot to mention the first five blinks of the power light.
    Yes the solution was helpful. Azraelsrl was very thorough in his answer and i will be recommending this site to others.
    Thanks
  • 11,800 Answers
3 blinks indicate that the power source is in protected mode because one of the components of the tv has failed and now acts as a short. The only way to know for sure which is the failed part is to open the tv and measure the voltages on the output lines from the power source - the one that is going to be close to 0 will point to the failed board.
Most likely it's the power board itself - one (or more) filtering capacitor has failed, a common problem in tv's of that age. But it might also be the Y-sus board - Emerson uses old Sony parts and they were notorious in that regard.
Posted on Mar 26, 2011
  • 2 more comments
  • Azrael SRL Mar 26, 2011
    5 blinks indicate a completely different problem - the digital/main board is not operational. This can be caused either by the failure of the 5 volts output line from the power source (no voltage - no operating processor - dead tv) of the failure of the processor. In the last case the entire board will have to be replaced. Check the status of the 5v line.
  • Elshamo707
    Elshamo707 Dec 19, 2013
    I have a emerson pl-p42w-10a that wont turn on and it blinks 5 times can you tell me what part I need to replace?
  • Dan Wetzel Feb 04, 2018
    I am having the same problem with the same tv. Have you figured out a solution yet?
I just noticed there is no input voltage to the power board on my Emerson plasma tv model PL-P42W-10A
check the bridge rectifier on the black heat sink left side bottom one with the + - and 2 squiggles on it.
Feb 05, 2018 | Emerson Televison & Video
I have a Emerson 42 plasma tv. model # PL-P42W-10A When I plug it on the 2 small rectangular components near the bottom of the power supply click and the standby light on front of the tv blinks 5x.
So, your TV does not come on? That part is not clear to me. I have seen TVs that do just that but is normal. Some machines have internal codes reflected by the infrared LED. When they sense power in the circuits they send internal signals to other components. If your TV does not come on at all then the issue is in one of the internal circuits, could be configuration issue, or that the power supply is at a low level. Please consider that the power supply in some equipment are voltage sensitive.
Feb 04, 2018 | Emerson Televison & Video
Can you give me the demensions of the Emerson pl- p42w-10a
we can not as we do not physically have one here to use a tape measure on
Jan 15, 2017 | Emerson Televison & Video
Video settings don't hold for more than 15min
Check capacitors. There are some very inexpensive meters for this and cheap capacitors are behind many problems in electronics. Once you find it is a bad cap you can replace it or the board.
Sep 05, 2014 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
I need a mounting stand for a emerson model #pl-p42w-10a
Search on Ebay.com for;
emerson pl-p42w-10a stand
Feb 26, 2011 | Televison & Video
I have an Emerson Plasma TV (PL-P42W-10A) and it cuts off the top and bottom of the screen. It just started doing this. The only sizes that are available are 16:0 Zoom1, Zoom2, and 4:3. The Wide Fit and...
Our prolem is no matter how we adjust the screen when ever there message at the bottom of the screen this don't show up or is cut off. I get upset when I pay the amount for this 42" Plasma TV and watching the news there extra messages across the bottom of the screen espically when school closing due to weather. I've try to figure out using the instruction booklet with no results. Any ideas where the screen to where extra messages in lower screen can be seen to be read?
kimandtomaleexander@gmail.com
Oct 26, 2010 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
712 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
