Question about Technics Audio Players & Recorders
There is nothing wrong with the wireing it dose not over heat so must be internal what do you think it could be
    Brigadier General:
  • 8,546 Answers
What product(s) are we talking about?
Posted on Mar 25, 2011
Why dose my pc keep beeping andCan some one help me fix my pc to boot and video to work ?
Check out this site to determine what the beep code is saying.
http://www.computerhope.com/beep.htm
Remove and re-seat your RAM sticks. Try to get to BIOS and load default settings are just a few things to try.
Jun 10, 2014 | Systemax Ascent PC Desktop
I think there's something missing on my bmw x5 audio left boot panel
Someone may have put a custom radio in it and then put the PEM one back when it was sold. You should go to a dealer and see if they will copy the diagram for the wiring for you.
Jun 11, 2017 | Car Audio & Video
I have a 1999 yukon denali when i trun on the heat or ac nothing happends no air or the motor dose not make a sound.. i think its not getting power becouse of a new system that was put in.dose anyone now...
Well it all go's to fuse box. there one under the dash (maybe in glove conpartment) and then there's one under the hood. your manual should tell you where to look for the right fuses. gl
Jan 21, 2014 | 1999 GMC Yukon Denali
The internal fan in front of the filter is blowing air into the panel where the wiring is and heating everything up and melting the wiring and limit switch
Think your talking about the inducer motor. If this is the case, make sure the exhaust pipe is attached correctly, and that there is nothing blocking the flue pipe.
Dec 14, 2012 | Coleman 7990-319p Evcon Gas Furnace...
I have a miller gold seal model 420 it always worked alright but now when i weld it welds wire right in the tip . i have changed the liner a couple of times and that doesnt do any good i have wrecked...
Hi:
If you are burning tips frequently, there's nothing wrong with your unit, it's just heat and wire speed fine tune you need. in order to avoid the wire/tip burnbacks, increase the wire feed to your unit, if you think this is too fast, then do the opposite, leave the speed as it is, but decrease your heat until you feel that the wire is kicking back the handle of your gun, then just increase the heat a little bit and that will be your ideal setting.
Hope this cure your probloem. Have a great day!
Jul 10, 2011 | Miller Welding Tools
Hello, I have a Ruud Silhouette II Plus 2 gas furnace installed in my garage. This is the first time that I've had a gas furnace (living on my own) so I am unsure of how it actually works. One thing...
If you have gas furnace, the outside unit will not come on unless you have dual fuel/ gas and heat pump. If you can look at wires in thermostat, if you have no wires going to O or B then you don't have heat pump. Normal tstat wiring for gas furnace and air conditioner. R,W,G,Y and maybe C.
Jan 24, 2011 | Heating & Cooling
My name is Sonny i have a question i just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 and then tempeture ran up 3 degree and stop dose not ran anymore what wrong with that can you help me...
Check temp setting must be +5 degree than room temp and also in heat "mode".
Check heating sensor placed perfectly. If not fix it in it's place. As it's running for 3 degree, your wiring no fault will be there.
Jan 19, 2011 | Heating & Cooling
Well i got a new power cord and now i think it might be charging but when i turn it on it still sufferes the same problem.. turning on than shutting of with nothing on the screen.. dose this mean the...
try turning it on with the power supply connected and the battery removed. you may just have a faulty battery. otherwise, it is likely an internal power supply failure. This is usually connected to the system board and would require replacing the complete system board.
Jul 11, 2009 | HP Compaq nc6000 Notebook
Protect light stays on
se if power suplie is 12/14V if not repair charger ,try disconecting all of outputs and it heats up (mosfet's)
May 04, 2007 | Power Acoustik TS1920-2 Car Audio...
18 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
