Question about Bosch Washing Machines
I have a bosch 1200 classix machine and its stopped dispensing water into the fabric conditioner bit
    Brigadier General:
  • 6,277 Answers
Sorry to ask but have you pulled out the dispenser drawer far enough to be able to just see the softener tray, then selected the (final?) rinse and checked that water is entering the tray? If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If water is being dispensed it could it be that the conditioner/softener tray is holding the softener rather than letting it be siphoned into the washer by the water, which is not uncommon. If so the softener part needs a thorough clean (see my complete guidance notes below, please)
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 25, 2011
Bosch classixx 1200 fabric softener dispencer doesn't empty into machine just fills with water
Pull out dispenser drawer in the middle section for fabric softener lift up top plastic cover and flush out hole with water and this should solve the problem
Jun 08, 2017 | Bosch Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Conditioner is staying in draw when water should be feeding into draw at end of cycle it is going into both other draws but not the conditiner one any ideas
Hi, welcome to Fixya. Immediately what comes to mind, actually two things. Fabric softner can often be too thick to dispense properly in front load dispenser's unless deluted half & half with water before adding. The other thing is this, it could be the water inlet hoses connected backwards, i.e. Hot going to cold and cold to hot at the washer, hence in the rinse cycle when cold water should enter the fabric softner chamber it doean't. Let me know what you find as I will look for your reply. Thanks for visitng "fixya". Please take a moment and rate this info accordingly but also let me know if you need further assistance. Good luck. Macmarkus :)
Jun 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
BOSCH 1200 FRONT LOADING WASHING MACHINE
BOSCH 1200 FRONT LOADING WASHING MACHINE.This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 20, 2010 | Bosch Washing Machines
Bosch classix 1000 express fabric conditioner won't empty
Get a piece of stiff wire, and make a right angled bend at the end of it, then poke it in all the holes on the top of the soap drawer compartment, this should solve your prob.
Please rate my solution.,
Thanks.
Jul 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Fabric softener dispenser no longer works on my Bosch, the dispenser remains full of fabric softener, all else ok Bosch classixx 1200 express
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Thankyou.
May 20, 2009 | Bosch Washing Machines
My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has...
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Aug 06, 2008 | Washing Machines
Conditioner drawer not emptying out (filling with some water but not enough to drain away) Bosch Classix 1200 thanks Bill
I've also got this problem and by taking the lid off I can see where the water comes in a tthe back of the machine there is a Solenoid (a switch that diverts the water during the programme to a 2nd water hose that feeds the conditioner) not working (I tested this by removing the hose from the output of the solenoid - turning on the programe and checking no water came out - this proved no blockage)
I can see the part is about £30 amd now looking to see how easy to is too fit
Jul 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classix 1200 washing machine fab conditioner tray (middle) will not empty
check the water in let valve connections and the current over it when it is in the fab cond. cycle. Replace valve if current is on. Valve price range is 15-35$
Apr 17, 2008 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
