Question about Chi Mei Corporation Computers & Internet
I used to be able to push the button on the side of my monitor & it would give me three viewing options but yesterday my son hit a button on the comp & now those three options are gone & are replaced by screens where i can input how bright, the contrast, etc...i liked it better the old way, any idea how to get back to that? my monitor is a chimei cmv221d
myjosh007
  • 530 Answers
SOURCE: Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Posted on Feb 26, 2009
  • 70 Answers
SOURCE: Monitor brightness contrast problem
Turn Off auto-adjustment screen
Posted on Jul 29, 2009
  • 355 Answers
SOURCE: Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Posted on Oct 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Whole screen has gone white, and doesn't display
Try this article on possible problems and remedies.....
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Posted on Nov 11, 2009
  • 27 Answers
SOURCE: Problem with IBM E74, a
if you increase them from the line in the board and the problem still you must exchange the line with another indeed its still in the market
if you not you must go to the line and deal with them
Posted on Mar 18, 2011
How do I synce the camera back to same monitor
I just barely had this problem and was able to figure it out.
You need to hit the "ok" button on the side of the handheld monitor. It will only let you select "add camera".
Hit ok again and it will give you a list of 4 camera's.
Now at this point you will need the actual camera and handheld monitor. You need to hold down the "code" button on the back of the camera and select "camera 1" in the list of 4 cameras. This should sync it back and you should have picture again!
I hope that helps :)
Apr 29, 2014 | Summer Infant Babies R Us Baby Sight Color...
My Gateway monitor scrolls through settings on right side of screen
Button may be stuck pushed in, use q-tip/alcohol to clean around the button.
Dec 23, 2012 | Gateway 24" Widescreen Flat Panel TFT LCD...
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
We have a Hewlett Packard F1703 monitor...... Our cat sat on the keyboard and the monitor screen went from a horizontal view to a vertical one. We have to turn the monitor on it's side to view it. We have...
Press CTRL + ALT + Down Arrow Key It will Work if Not then Righ Click on Desktop Screen -> Graphic Properties -> Hot Keys ->Uncheck or Check the option it would be done
May 30, 2010 | HP Pavilion F1703 17" LCD Monitor
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
View is vertical not horizantal
Ctrl-Alt-Up Arrow key
Or look in Control Panel>Display>Adapter settings for settings specific
to your video card.
Jun 25, 2009 | Computers & Internet
I have a Nikon d70, and I can not get it to display only one image on the LCD screen. I have held down the button on the top right side as directed, but to no avail. Help Jb
Push your playback button once the camera is on.
Then push you your thumbnail button. (this is the second button from your playback)
watch your monitor and keep hitting the thumbnail button until you get to the single picture view.
Dec 07, 2008 | Nikon D70 Digital Camera with 18-50mm Lens
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Open Questions:
cmv221d wont power on even after changing capacitors Not even the LED or any response from the screen, nothing.. I ordered replacement capacitors, all except the big 400v one, replaced them all.. nothing's changed. I've ordered the big capacitor's replacement just incase, but heard they rarely break.. any other ideas of what the problem might be? The guy who gave me it said that he thought all that was wrong with it was a line across the screen (corresponding to where he said that line was, I found some dirt on the edge of the connectors). It actually did not power on as it was supposed to, according to the previous owner, who made no profit by giving it to me. A tiny part of the circuit-board did get slightly peeled when pushing one capacitor in, but only about 3mm across, affecting two small strips of whatever those little chrome strips are, but I soldered it back down.. I may have also re-attached the large Capacitor, and in folding it back down, had to force it.. could this have internally damaged it easily? This is the first time I've done anything like this, but I have followed a tutorial and learned the correct technique for soldering. Does anyone have any ideas what else it could be? The fuse looks fine. The power cable works in other monitors. I hear a little crackling if slowly pulling out the power cable as you'd expect with any screen if you listen close (atleast in Australia, I remember being surprised at how much things crackle here after moving from the UK). But yeah, basically the screen is stone cold dead, no response whatsoever..
Dec 27, 2012 | Chi Mei Corporation CMV-221D LCD Monitor
Computers & Internet Logo
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
