Question about D-Link DIR-600 Router
I have D-Link DIR-600 Router . there was some problem in my pc and I formatted after that when try to connect using wireless it says acquiring IP but it never acquired, I ran diagnostic where it was failing for authentication, then I decided to reset to factory settings but it is not happening, any help would be higly apprecited.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
What SO you use? try to update to the last service pack.
and try again
Posted on Mar 25, 2011
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
Dlink DIR 600 Sify
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
You should be able to configure your router using the wizards. Login is ADMIN and Password is blank unless it was changed by the user.
Feb 18, 2013 | D-Link DIR-600 Router
Can't connect XBOX 360 S to D-Link DIR-600 Router
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Mar 04, 2012 | D-Link DIR-600 Router
Ever since the storm I can't get online wirelessly, I can't get on with the internet cable direct but not with the dlink 600. Please help.
check
1.- Cable leave modem is attached to Port WAN (they are others 4 ports LAN)
2.- In router Dlink DIR 600 led Internet in On or blinkling
3. using web browser type http://192.168.0.1 (this is IP default )
4.- reset your DIR600, using a clip press in reset Hole 10 seconds
5. Try again using web browser type http://192.168.0.1
If connect, re configure your modem for your wireless network
Sep 14, 2011 | D-Link DIR-600 Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
I can connect to internet by D-Link DIR-600 using LAN port but there is no internet by wireless. All clients can connect to the router by wireless and they get proper IP but there is no internet.
My first thought is that it sounds like a DNS issue or you don't have your default router(default gateway) set on your wireless network card. Make sure your "wireless network card" is set up for DHCP.
Try this:
1. Goto your command prompt (cmd / the "old dos" window) 2. Type ping 74.125.225.20 and hit enter
If you comes back with Request Timed Out then it is default router issue. If it comes back with Reply from .... then it is a DNS issue.
Either way having your wireless card set for DHCP instead of static addressing should fix it.
Mar 06, 2011 | D-Link DIR-600 Router
How to block my wireless router dir 600
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 27, 2010 | D-Link DIR-600 Router
How do I change my security settings in my dir 600
If not then you will need to connect the computer to the router with the cable. Do not change wireless settings using a wireless computer.
Click Here for step by step instructions
Mar 01, 2010 | D-Link DIR-600 Router
Cannot get computer to connect to the router via cable. Says acquiring ip then fails.
are there other computers that are successfully obtaining IP address/connecting to the internet through the router? Try the basics first --use another ethernet cable (a known-working one if possible), use another port on the router, power off and on the router.
Jul 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR-600 Router Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
