Question about Toshiba Fuj 600gb 10k 16mb Sas600 30ms 35 Brk Hard Drive
My toshiba hard drive is not working the light is only blinking and my files are not comeing up..
  • Toshiba Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Posted on Mar 25, 2011
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
Toshiba 750 canvio
POR FAVOR QUIERO LA CONFIGURACION DEL DISCO DURO EXTERNO ... Y EL REGISTRO PARA REGIRTRARME
Sep 23, 2012 | Toshiba Canvio 750 GB USB 3.0 Portable...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I have external toshiba harddisk MK1234GAX .when i connect to my laptop its not detecting only red and green light blinking..its not showing on my computer..i need all the files in tht hard disk..please...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 21, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Blinking cursor after recovery CD
when cursor blinks, try to press any key!
tell me what error message it gives than!
Dec 29, 2009 | Toshiba Satellite A60 Notebook
Toshiba tecra m1 : can't boot
this is due to the bios problem. check for bios update from service provider then press fn+esc+power button when light start blinking put your pen drive in the usb port after 1 -2 min, it boots up . that files are like flashget etc.
Aug 08, 2009 | Computers & Internet
Toshiba Fuj 600gb 10k 16mb Sas600 30ms 35 Brk Hard Drive Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
