Question about Toshiba 36A61 36" TV
Remote i on tv
Electronic eye will not let any remote work. does not respond to the original at all. have to push buttons on tv it self....
From elsewhere... in case it helps
"...and an intermittent problem responding to the
remote. I had a service person check it out and was going to have it
repaired because it still looks and sounds very good. The part was
available at a cost of about $85-90 plus about $40 for the service.
However, the service person didn't want to come back again for
another service call because I was too far and it was not profitable
for him, so the part was never replaced.
The remote control is OK. It is the receiving module in the TV that
has a low voltage problem. If anyone is electronically handy it
probably is an easy fix to install a new module or it can be use
without the remote with the buttons on the TV."
Posted on Jan 14, 2009
How do i know if the eye for the remote works
First, determine if the remote is working. To do this, if you have a camcorder or a digital camera, point the remote control at the lens of the camera as if you were pointing it at the TV. Now look at the picture of the remote on the camera's screen and press any button on the remote. If you see a flickering light on the remote then the remote is functioning. You can push each button to verify it works. Results: If the remote doesn't produce the light, change batteries and try again. If still no light then the remote control is defective. If light is produced and the TV doesn't respond then the the eye in the TV is not working.
Dec 31, 2014 | Sharp Aquos Televison & Video
Recommended replacement remote for 32c11ou
i would make sure you have good batteries in remote and if you have a cell phone with a camera you can point the camera at the remote control where the bulb is that you point at the tv and push a button on the remote control and the light will show up in the camera as a blue light the camera will pick up the ultra violet light that your ***** eye won't see if still bad almost all universal remotes will work but usually problem is battery or corroded battery connectors good luck
Aug 05, 2012 | Toshiba Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
The battery is brand new on my remote and the red light flashes when I push button but the tv doesn't respond.
Is it one of hose remote that needs to be programmed for your TV or original reamote?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Please post back.
Oct 29, 2010 | Sharp LC52D85U 52 in. LCD TV
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv not responding to remote or buttons on tv
Well okay!
couple of questions?
1) Is a multi remote - does it or can it control other components like a DVD player or a VHS or Cable box?
2) If it does - you may have selected one of these other components to control
NOTE: Try depressing the TV button and then try the other buttons such as channel or volume to see if it's back working.
Blessings,
A/V Guy
Nov 19, 2009 | Element Electronics FLX-2210 22 in. LCD...
My Sony 55" HD keeps turning off by it self
could be the remote sencer that is in the tv or bad swithes that are leaking. I have seen this happen before the sencer is a small electronic eye that picks up the signal from your remote when you push the buttons on it. The switches im talking about are small button switches that are soldered to a board right behind where you would push the power button and chanel buttons on the set itself. I would start with the switches frist if it was me. Some times you can trace the wires on the front where the switches are and unplug that set of wires and stil use the remote to turn on the set to see if it still does the same thing. The remote sencer on some models are pluged in seperate if so then this should help you to trouable shoot this problem.
Feb 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Toshiba 36A61 36" TV Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
