Question about Nikon AF-S Zoom Nikkor 80-200mm f/2.8D ED-IF Autofocus Lens
My Nikkor AF 80-200 lense suddenly won't focus in af mode. Focuses manually. Camera was checked with another lense and its af works fine. What should I expect is the problem?
4 Suggested Answers
  • 13 Answers
SOURCE: Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Posted on Jun 12, 2009
  • 37 Answers
SOURCE: Nikkor AF 80-200mm f/2.8D ED Lens, with broken auto/manual ring
Depending on where you live, you can take it to an authorized Nikon repair place or just send it back to Nikon.
In the US, they are in Melville, NY and ElSagundo, Ca.
Posted on Jul 14, 2009
ftw1952
  • 10319 Answers
SOURCE: My Nikkor AF-S DX VR 18-200 stopped focusing
the lens internally has a electrical circuit ribbon that contracts when you adjust the lens everytime. They are prone to get crease causing a short in the auto mode.b It can be checked and replaced bt most camera technicians
Posted on Nov 06, 2010
Will not auto focus
If it manually focuses and not auto focus you may have a broken ribbon cable in the lens. If that is so you'll need to take it to be repaired / cable to be replaced
Jan 30, 2014 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Sep 26, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon AF-S Zoom Nikkor 80-200mm f/2.8D ED-IF Autofocus Lens Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
