Question about Bosch Dishwashers
GOOD AFTERNOON i HAVE A SCA24 CLASSICXX DISHWASHER THE CONTROL PANEL DISPLAY WILL TIME DOWN TO I MINUITE AND THEN STAYS AT THAT TIME WITH WHOT SOUNDS LIKE THE PUMP STILL GOING. AND ALL THE ITEMS INSIDE ARE STILL WET
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is
likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck.
Regards,
Macmarkus :)
Posted on Mar 25, 2011
The dishwasher continue beeping one sound every few minutes, even after I shut down the power. Why and how I can fix it
Good Afternoon Tie, thank you for your inquiry!
From what you have described your Frigidaire dishwasher continues beeping a sound every few minutes even when the power has been shut off. It sounds like this could be a possible issue with your control panel or keypad. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. I hope this information is helpful for you. -Matt
Aug 06, 2015 | Frigidaire FGBD2431KF Dishwashers : Built...
Oven shuts off . lights still work . temp drops but display stays same
Good Afternoon David, thank you for your post!
From what you have described your Frigidaire range your Frigidaire oven shuts off and display remains the same. This could be a faulty control panel or wiring harness. In order to diagnose which component could be the problem you would need to disassemble the range and test each electrical part. I would recommend this be completed by a technician for proper repairs. This will help you avoid any unnecessary part purchases. -Matt
Apr 23, 2015 | Frigidaire Kitchen Ranges
My electrolux dishwasher model EWDW6505GS0 will not turn on. The electronic display only indicates "Welcome" for a split second and then goes out and nothing lights up on the panel and cannot get it to...
Good Afternoon Will, thank you for allowing me to assist you!
How long did you leave the breaker off? It is important to wait roughly ten minutes and then your dishwasher on. If resetting the power does not correct the issue, then it sounds like your dishwasher could possibly be experiencing a communication error with the control board/panel or a potential wiring failure. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jan 11, 2014 | Electrolux EWDW6505GS Fully Integrated...
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
KitchenAid KBMS1454R 1000 Watts Microwave Oven
Sounds like the keypad is okay, unless it might be intermittent.
Your wall voltage is within the proper range.
It sounds like it might be bad connections on the control board causing functional and display problems.
I work on control panels, actually, but I can't find any service data (yet?) on this model.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Did you find it?
Any chance you could scan and e-mail it to me?
Please feel free to contact me directly.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 04, 2008 | Microwave Ovens
Problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
4,317 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
