I have a small safe, it is a budget electronis combine lock. I have just replaced the batteries and have mislaid the instructions. How do I reset it and enter a new pin number
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 57 Answers
SOURCE: I have a sentry fire safe with an electronic lock
Normal 0 I found this hope it will help. So I called the sentry safe company, (800-828-1438), and waited for about 10 minutes to speak to a representive, (that was alright since I have a speaker phone). The first thing they asked me was about the condition of the batteries. I told them that they were brand new. The person then asked about the brand name and expiration date of the batteries. They were generic batteries, but the expiration date was fine. They suggested a new set of batteries, and mentioned that I could bypass the battery pack, (which sometimes fails), by unplugging the pack and using a regular 9 volt battery.. So just to cover the base, I went down to the store and obtained a brand new 9 volt duracell battery. I unplugged the battery pack and plugged in my new battery. I then pushed the combination numbers and my safe again failed to open.
I called the sentry company back using my speakerphone feature again while waiting to speak with a technician. The tech asked me about the batteries and I told him it had a new 9 volt at the last technician’s recommendation. The person began to talk about the actuator cylinder inside the safe, stating that it did not sound like it was actuating. Then they told me something that really made me wonder about the quality of this safe. They told me I would need to hit the safe with a rubber mallet in an attempt to get the actuator to engage so I could open the sentry safe. OK, so the safe is supposively built to keep my belongings safe from thieves and fire, but now I am going to fix it with a rubber mallet? Good thing my sentry safe was inside, somebody might have wondered about my mental state if they had seen me beating this fireproof safe with a rubber mallet! (PS: If you use the rubber mallet option or any other suggestions that sentry’s customer assistance supplied, and have firearms or dynamite in your safe, you do so at your own risk, use wise judgement for your own safety)
Well it just so happens that I had a rubber mallet and did not need to once again go to the store to get something to personally fix my great sentry fireproof safe. So I begin beating the sentry safe with this mallet and then tried the combination again. Woolah, It opened! I stopped for a moment and began to ponder how many other things I could fix with this magical rubber mallet. I mean, what about the TV, the computer, my fridgerator and that cell phone that always drops calls? Could it be that I have discovered the fix all to all mechanical issues? As I began to look at my belongings in my fireproof safe that I have just opened with a rubber mallet, I thought "so if I close the safes door will I need a sledge hammer next time"?
Time for another phone call, back to the speakerphone. The technician this time listened to my issue and asked me if I had some lubricant like WD-40 with a small tube that attaches to nozzle. I thought, "well of course I do, I was just using that to fix the broken water pipe in the garage." The phone tech tells me where to spray the lubricant on the inside of the sentry safe door. He has me do this in the open and closed combination positions, and it’s now opening when I press the combination numbers with the door open, hurray! The only problem is that after working in the lubricant a few times the handle on the door does not lock into the locked position. I no longer need the combination to unlock my safe, I only need a can of lubricant! OK, this is one really tough safe, what thief would ever think that they would need a rubber mallet and a can of silicon lubricant to open up a safe?
Back to the speakerphone, this time a lady technician. She wants me to get a screwdriver and pry off the plastic piece on the back side of the door. At this point I said to her, you have built a product that I need to have a rubber mallet, a can of 3 in 1 spray lubricant, and a screwdriver to open? She stated that she was doing all she could to help me fix my safe and asked me how long I had owned the safe. I told her about 2 years and she stated that it was out of warranty. I thought, well who needs a warranty when they have a magical mallet, a can of black led, and a screwdriver? Anyway she directs me to pry the plastic backing off of the door and when I do this little piece of plastic falls out onto the floor. I look at this little plastic piece pondering in my mind, what’s it’s part in all of this. Well the technician is directing me to look at the arms and gears and some arrows that line up between the metal arms and plastic gears. What’s wrong with that picture? Metal and plastic don’t really work together long before the plastic breaks. I had to wonder for a moment, is this some really expensive fireproof plastic? The arrows line up and with that information she directs me to the area of the actuator again, she says "you see the circuit board" and a little white button that sticks out from it?" I said well yes, I see the circuit board and the little white button you are talking about seems to be laying on the floor broken off. So I picked it up and said, "this little broken piece of plastic that connects to the metal arm on the safe is why the safe does not work right?" She tells me yes that’s the problem, that i have broken it and since it’s out of warranty that there is nothing she can do to help me. But she then asks me to hold on for a moment…..
She comes back to the phone sounding sincere, like she has just solved all my problems, and tells me that she has spoke to her supervisor and that they can offer me 10% off on any safe that I would like to purchase. I thought what great customer service, now they want to sell me another safe with metal and plastic pieces that break and give me a huge discount of 10%, and I bet it comes with a free maintenance kit which includes a polo stick, some lard oil, and a screwdriver on the rocks! Needless to say I declined their gracious offer.
I will say that all the organizations personnel, (that I spoke with), were courteous and trying to be helpful, (that was within the realm of authority they were given). With a product such as this, and the great customer service I experienced, I thought it was probably best to find a safe that was free of little plastic pieces that break off, cause those plastic pieces won’t save you 10% !
Posted on Oct 08, 2009
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Posted on May 25, 2010
SOURCE: I purchased a new Sentry
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Posted on Sep 13, 2010
How to reset safe combination
Need to know the make and the model
Apr 30, 2017 | The Home Security
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    The safe i have is locked with the door open. How do i reset the safe to close the door.
    Remove the batteries end leave it for 10mins or so..then replace batteries and set a new combination on the lock.
    Feb 24, 2015 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Why won't my safe open? I have 3 keys that fit, door won't open . I don't know combination.
    There should be a serial number on the safe. You can google the manufacturer and get a contact number, call them and they will be able to walk you through resetting the combination. But it sounds like you will need to replace the battery in it first
    Dec 02, 2014 | Home Security
    Why won't it lock?
    The replacement battery could be defective
    Apr 10, 2012 | Stack-On Stack On 16 Gun Safe with...
    Nutool sf20 safe
    I need an instruction Manual for a Nutool sf20 safe
    Jul 15, 2009 | Computers & Internet
    Century safe lock , not able to open the combination lock oper b
    Apr 28, 2009 | Safe International Digital Electronic Safe...
    Nutool sf10
    Why don't you just use the overide key?
    Oct 18, 2008 | Computers & Internet
    Small floor safe Sentry Model 3877 electronic lock and key
    This manual will answer both of your questions.
    http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
    Feb 21, 2008 | Sentry Fireproof Safe
    304 people viewed this question
    k24674
    jasbo
    jasbo
