Question about Proform Crosswalk 500 Treadmill
Here's the problem when you turn on the treadmill it runs fine until you put your weight on it. Once you stand on the treadmill with the belt running it gets stuck?
  • rprinstein Mar 25, 2011
    is it the walk belt that stops and motor and front roller still turn or does the walkbelt and the front roller stop and just the motor runs or does the motor stop only
    Top Expert:
  • Proform Master
  • 12,223 Answers
This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the
belt or when the treadmill operates normally for a given period of time
with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time
Test every step.
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
Posted on Nov 15, 2011
Everytime I stand onto my treadmill, it works, and then all of a sudden stops and runs very slow. When there is weight on it, it doesn't work. When weight is off it, it works fine. Whats the problem?
Try to clean the dust inside the running belt and silicone them after.
Then try to increase the belt tension. all treadmills have these adjustment.
If it still slip, then problem with the motor.
Feb 10, 2016 | Nordic Track Exercise & Fitness
When I get on treadmill it slows down andjust about shuts off. Im 265 pds, My wife gets on @ 160 pds the treadmill runs fine. I ADJUSTED THE BELT LOOSER AND IT STILL RUNS THE SAME. WHAT CAN I DO TO CORRECT...
Loose is not the answer. Proper lubrication and correct tension adjustment is the answer. I don't know how many HP the motor is for, but for 265 pds it should be at least 3HP.
Put the speed at about 3MpH and while walking, make a small jump on the belt to ensure that it is properly tensioned. Needless to say that the belt must be well lubricated. If you see that the belt tends to stop when you make the jump, turn both allen screws exactly the same amount clockwise. Half a turn might be enough. When you're satisfied and the belt doesn't seem to stop, give both allen screws another half turn clockwise.
All that as long as the treadmill is capable of handling your weight.
Jan 17, 2014 | Proform XP 580 Trainer Treadmill
Accusmart treadmill
see the video and lube the rollers bearing front+back too. Test the drive belt motor, and see if there are loose or faulty, and repair + or replace.
God bless you
Oct 31, 2013 | Exercise & Fitness
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
Hi, my Pro Form 470cx has just started to stop when I walk on it intermitently. The belt is running perfectly until I stand on it and then it appears to stick instantly on the base causing a stall in the...
Susan,
The most common cause of belt slippage is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Sport & Outdoor - Others
Treadmill slows suddenly and when i step off it starts again. only happens to me.
hi it sounds like the belt is too loose, i had the same problem when the wife uses the treadmill works perfect, untill i step on it really slows down and once i step off it runs fine. so i tightened the belt just a fraction and now works fine. check your instruction manuel it will explain how to do this. normally its two screws at the backend of the roller. hope i have helped.
Nov 15, 2010 | Proform XP Weight Loss 620 Treadmill
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
When weight is put on belt it stops. works fine by itself at all speeds
If you can stop the belt. You need to be aware that both running & drive belts can cause the same problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | Proform Sport 1000 Folding Treadmill...
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Jul 14, 2009 | Exercise & Fitness
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Proform Crosswalk 500 Treadmill Logo
296 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
