Question about Whirlpool AD50USR 50 Pint Per Day Ultra Low Temp Basement Dehumidifier w/ AccuDry Sensing System &EN... Humidifier
I have a basement dehumifiier and I think there should be a way to clean the filter but don't know how to go about it?
    President:
  • 2,468 Answers
You can unplug the unit,then remove top cover rear screw,then 6 screws on side of front grille,then all screws around the rest of the units wrap around cover,being careful to not stress any wires in doing so,then carefully blow out inside components out with low pressure compressed air or a vacuum cleaner
Posted on Mar 25, 2011
I have a 2 yr old dehumidifier and it runs, it just won't pull out the moisture out of the air.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(No LED screen), set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you and thanks for choosing FixYa
Sep 13, 2011 | Kenmore 938060 Humidifier
DEHUMIDIFIER IS RUNNING BUT NOT COLLECTING WATER
level
problem.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 28, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
the unit without the filter. Filter should be cleaned once every 2 weeks.
level
problem.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
I have a Whirlpool AD70U dehumidifier with type 3 controls. I have the fan set to auto and the humidity to normal. The unit drains into a floor drain. It seems dry in my basement yet the fan seems to run...
If it's set for Continuous Mode the fan will run all the time. It does so, in an effort to keep recycling the air. Once it senses a rise in humidity, the compressor turns ON. Check the settings, to be sure it's where you think. Also, check and clean the air filter, if necessary. Before removing the filter, be sure to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. If you wash the filter, it most be completely dry, before reinstalling it. Do Not operate the unit without the air intake filter installed.
Make sure you are maintaining at least 12" - 18" clear air space around the entire unit.
To further assist you, in case you have misplaced your Owner's Manual. I have included a link to it, that you can download and print for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helped you to further troubleshoot and solve the problem.
Jun 21, 2011 | Whirlpool AD70U Humidifier
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Odor
First, clean or replace the filter. Next, mix a very weak solution (40:1 ratio) of bleach and water to fill the unit. the bleach will kill any bacteria that could be causing the odor, but NOT harm anyone, The filter will take care of any hard water issues. Just don't make the mistake of thinking "If a weak solution is good, a strong one is better". NOT TRUE. Stay with the 40:1 mix unless you like breathing bleach. (Yuk) Note: It may take a couple of days for the odor to go away.
Feb 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Whirlpool AD50USR 50 Pint Per Day Ultra Low Temp Basement Dehumidifier w/ AccuDry Sensing System &EN... Humidifier Logo
75 people viewed this question
Top Whirlpool Humidifiers Experts
Paul Carew
Dennis
Are you a Whirlpool Humidifier Expert? Answer questions, earn points and help others
