Question about Acer (54.AA806.001) Sound Card
My audio jack is not working .................why .....................
  • Acer Master
  • 27,725 Answers
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
also if you mean that your microphone wont work from the audio jack
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
hope this helps
Posted on Mar 25, 2011
Audio jack not working for my earphones?
I would try another set of headphones and see if it works. Try changing the volume level and see if that helps. You could also try a set of powered computer speakers to test the jack. The audio jack may not output enough power for your headphones. There is also a chance the audio jack could be defective.
Oct 26, 2016 | Televison & Video
My new Vidwo carde disabled my PC sound jack, but I have audio from my USB headset. How do I get my audio jack and external speakers to work.
Find and Try reinstalling Driver for onboard audio look in device manager and see if there is an exclamation mark next to your sound hardware, also there maybe an audio out jack on your vid card that has priority over your onboard since its hd
Jun 19, 2012 | Compaq Computers & Internet
When I update my realtek audio driver my headphone/mic audio jack stops working
you may have to set your audio input/output device back to the jack
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 10, 2012 | Dell Inspiron N5030 Notebook
WILL THIS HEADPHONE/MIC SET WORK ON A SMART PHONE THAT ONLY HAS ONE 3.5MM FEMALE JACK. YOUR SITE DOESN'T SHOW THE EMD OF THE CORD IF THERE IS ONE OR TWO MALE JACKS.
http://teknmotion.com/contact.htmlGood Question. I decided to give them a call, and the rep confirmed that there are two jacks at the end of the cord one for audio out, the other audio in.
This product would not necessarily work on a single jack smart phone due to the dual 3.5mm jacks.
Hope this helps
Apr 07, 2011 | TekNmotion PC Yapster Headset White
Back panel audio jack is good condition I hear from back panel audio jack but front panel audio jack is not working.
hello,
Go bios prees by F2 / F10 /del set the azilla audio enable .
Reinstall the audio driver again.
Hope it will help you.
Dec 23, 2010 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Monitor's audio out not working
You need to connect a line out from your PC audio card (green mini stereo phone jack) to the monitor audio line in jack (green mini stereo phone jack)
Feb 16, 2010 | Computers & Internet
Can't get my laptop speakers to work through headphone jack
the reason for this is that the audio thru this jack is attenuated to a level where you don't loose quality and to prevent ear damage. You better try the audio out or audio monitor output jacks located in the back of the tv(if this model comes with them). you'll probably need an audio amp to get the speakers to work properly though.
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Feb 25, 2008 | Zenith D52WLCD 52" Rear Projection...
Lost Owners Manual - Can't get Audio Out Jacks to Work
the manual is avild here http://www.manualsparadise.com/pages/P061220/P94561532.html
but look and see if there is a switch on the back of the tv that sayes external speakers, if so us that and you book self speaker will work, also check in the menu under audio for this same setting, if none of these are there look at the back again this might be a audio out jack that is made to go into a amplifier
hope this gets you on the right track
Feb 08, 2008 | Zenith Z27H41D 27" TV
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
