Question about Bosch SHE4AP06UC Dishwasher
Bosch she4ap06uc/06 not draining. Filter has been removed and cleaned, still have problem. Also, when dishwasher is on, after about 5 minutes says dishes are clean.
SOURCE: Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Posted on Sep 20, 2007
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Feb 20, 2008
  • 1462 Answers
SOURCE: My Bosch dishwasher model #SHU43C05UC/14
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Posted on Jul 14, 2008
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Posted on Dec 19, 2008
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 13, 2011 | Dishwashers
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
Dishwasher won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 21, 2010 | Bosch Dishwashers
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Daniel
Jul 22, 2010 | Bosch Dishwashers
Cleaning the drain of a bosch dishwasher
had the same problem if you remove t20 screw on the left side of the bottom bowl & remove plastic cover this is the drain pump & can block with food or glass particles clean it out & check it revolves & should be ok
Jun 16, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch SHE4AP06UC Dishwasher Logo
153 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
