Question about HP LaserJet 2550n Printer
I have a HP 2550 Laser Printer and using the front loader and not trays. My Amber light is blinking. There is paper and I looked and there is no paper jam. I uninstalled the printer and installed it again and this time I got an error Paper Jam. I checked again in the front, under the drum in the back and took the back panel off and there is no paper. I plugged the printer back up and turned it on and still saying paper jam. Is there a way to clear the error memory (hard Reboot)???
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
AdamEntity
  • 14 Answers
SOURCE: Paper Jam Error on HP 2015
For whatever reason the printer internal programming became corrupt showing that there is a paper jam. After checking the paper path and a quick can of air sprayed into the tracks, I proceeded to attempt a Cold Reset.
1) Remove the paper tray.
2) Remove toner cartridge.
3) Unplug USB.
3) While plugged in to power, turn off the printer, hold down the 'GO' button and power it back on. Continue to hold for more than 5 seconds but less than 15.
4) Reinstall the tray (be sure to check the paper level indicator is operating when you add paper to the tray. The lever should move up as it fills with paper)
Reconnect the USB cable (make sure you are using a thick USB cable and not a cheap thin one, very important. Make sure the printer is not plugged into a backup batter either) Never plug a printer into backup power.
I noticed that the computer did not recognize the device when connected which prompted me to contact HP support.
HP Support is shipping out Item # CE517AB - Font/DIMM Program for me to install in the printer to most likely reinstall the firmware.
I will post back if this works to flash the firmware or just waste some time.
Posted on Aug 06, 2008
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Hp color laser jet cp4025 blinking yellow light
Yellow toner is getting low, or check to make sure your print driver is set correctly for this printer.
Mar 22, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
HP 2200D Amber light keeps flashing! ..and nothing else
Following are the reasons and its solution for amber light keeps flashing:
1. Toner have been empty.
Sol : Refill you toner.
2. Printer's paper tray do not close properly or paper in not in the tray.
Sol : Close the paper tray properly and keep some papers in the tray.
3. Any door of printer is open or not properly close.
Sol. : Check all the doors that is close properly or not.
If problem is still remaining then contact a professional to repair this printer.
Regards
Ashly
Feb 25, 2010 | HP LaserJet 2200D Printer
My laserjet 2550 won't print. The light beside the triangle is blinking but I don't know what that means.
Hello there,
What is the color of the blinking light? Is it red or green? If its red, then there must be a cartridge issue or paper jam. Did you load the paper correctly? Also, please try to do a reset of the printer.
Aug 03, 2009 | HP LaserJet 2550N Photo Printer
My 2003 laser jet 1320 suddenly quit printing.
Good chance something is wrong with the tray, are you able to print of you place paper in the multi-purpose tray (tray 1)?
If so, one thing that may be your problem in tray 2 is here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974
Feb 28, 2009 | HP LaserJet 1320 Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Hp 2015dn paper jam light on solid,won;t print
This is a widely known problem with this printer and means the formatter board needs to be replaced. Save yourself the cost and headache of repairing and move on. The problem initially began as a random situation where I would have to turn the printer off and back on to get it to print.This eventually progressed to the problem you all are reporting which is the amber toner and jam lights on. I replaced the formatter board on mine and after one month the problem returned with the new formatter board needing replaced as well.
Of course, HP acts as if they've never heard of the problem. This company's integrity and quality has gone from number 1 to dead last.
Dec 09, 2008 | Office Equipment & Supplies
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
Printing problem
Amber/orange light blinking and not printing
Jul 07, 2008 | HP LaserJet 1320 Printer
Only the orange light is on
the feeding tray having foreign materials sruck the paper loading
Jan 04, 2008 | HP Laser Jet 1320 Printer
HP LaserJet 2550n Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
