Question about LG 22" FLATRON LCD Monitor
I get shadows or lines appearing after the word on my monitor. How do I fix it? I have tried to work with the buttons on site but it doesn't correct the problem Sometimes I move my monitor and it gets better but there is always that shadow. I would like it to be clearer.
  • 115 Answers
The physical lcd is having problems. LG monitors come with a 4 year warranty. contact the reseller or the manufacturere directly and they will reapir the unit for free. will take about a week and a half. stinks to not have a monitor but at least its fixed for free.
Posted on Mar 25, 2011
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
Ocasionally diagonal lines appear on the monitor or the whole pcu turn off by its self. When thie lines appear the only way to get going again is to manually hit the power button on the tower unit
Hello. Have you tried using this monitor on a different computer? This would help us understand if this is being caused by your computer/video card or the monitor itself is dying and needs to be replaced/fixed.
Jul 18, 2011 | Gateway FPD1760 17" LCD Monitor
All the icons, pictures and letters are creating shadows on the monitor. How do I get rid of them?
try this right click on your desktop , click on Appearance tab . then click on effects , see if Show shadows under menus is checked if so uncheck it . click ok then click Apply .
Sep 20, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My monitor has a line down the middle with a shadow on one side of theline and I have osd locked on the screen and cannot get the program to show on screen to fix it
Vertical line down a monitor with a shadow genearlly is an indication of a video cable problem. Try removing the video cable from the computer and if it is still there and OSD is still locked it is an internal logic circuits problem
Dec 17, 2009 | LG Flatron L1515S 15" LCD Monitor
Shadows around the objects
One common cause of ghosting is an inferior monitor cable. Remove any extension cables and check again. The monitor may be getting interference from another device nearby, such as a printer, for example. Try turning off/ disconnecting other devices and see if the ghosting disappears. If so, you could buy a better shielded cable, or rearrange your components to prevent the interference.
That would be a simple fix if it works....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | Acer AL2216W LCD Monitor
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Desktop icons appear as a shadow on all windows.
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Sep 29, 2008 | Acer AL1714 17" LCD Monitor
Problem with shadows showing on monitor
The solution to this is very simple. No software or hard ware changes required.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Thin pale Horizontal line
I tried this and it has worked temporarily by banging the monitor not great but it did work, no tech knowledge if there is any other advise please email.
Hiyama Monitor Model: Vision Master 17 (8617E Chassis)
Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
(John)
Aug 20, 2007 | Gateway FPD1975 19" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
159 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
