Question about GE Radio Communications
I have taken an operational GE Master III Repeater and attempted to program it to be a Base Station with (2) frequency's. I am replacing the Motorola base station that has a dedicated phone pair to the dispatcher. I can hook up a tone remote and talk to the dispatcher over the phone line but can not talk on the reprogrammed Base Station. I am using a floppy disc TQ-0619 Version 9A for the reprogramming.
4 Suggested Answers
  • 105 Answers
SOURCE: Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
Posted on May 23, 2008
  • 258 Answers
SOURCE: Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Posted on Aug 15, 2008
  • 1654 Answers
SOURCE: Motorola Talkabout T8510TPR frequencies
Here is a copy of the user guide
The frequencies are listed in a chart on page 2.
Best regards.
Posted on May 26, 2010
Testimonial: "Very helpful! Thanks :)"
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Will not transmit to a repeater
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Nov 29, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
How do I program a yaesu ft-270?
I will be working from the online version of the manual located here. It may or may not be the same as your printed manual included with the radio - so you might want to download this copy.
First, let's set the radio to automatically set up repeater input shift based on the published receive frequency. By default, the 270R will transmit 600Hz up or down as determined by the band plan. This feature is called ARS and can be disabled if desired. If it does not display a frequency 600Hz up or down from the receive frequency while transmitting, is has been disabled. Let's re-enable it by performing steps #1 thru #5 on page 19 of the manual. Once completed, the 270R will automatically shift the transmit frequency (to match the repeater input frequency) as shown in the top half of the "ARS-Repeater Subbands" graphic at the bottom of page 19. The bottom half shows the export version of the shifts and does not apply to USA versions. If you have "odd splits" (repeaters that have input frequencies that are non-standard ie: other than 600Hz; or shift up instead of down and vise-versa) you'll need to manually change these later as described in VHO Split Mode on page 21. Any repeater operating on 147.000Mhz may have a shift either UP or DOWN. As you can see in the graphic, 147.000 is between the (-) and (+) shift so it could be either direction. Double check to make sure the radio matches the shift that the particular 147.000Mhz repeater you wish to access requires.
Next, create a list of repeaters that you wish to save in memory (you can check online databases to obtain the most recent information). This list should include Name, Receive Frequency, any non-standard direction or value Shift (called "odd splits), Tone Type and Tone. The name should be 6 or less alpha-numerics in length and be something that helps you identify it . This could be the name of the repeater owner: "TIM, PETE, etc. ", the name of the club that runs it: "BARC, CMARA, etc.", the city or town it is in: "BOSTON, OAKLND, etc,". You might run into names that would create duplicates when there are more than 1 repeaters there in the same location. Boston has several 2M repeaters - naming them BOSTN1, BOSTN2, etc. may help you remember them, but it will be easier still to append the decimal portion of the frequency to remember - such as in the case of a Boston repeater on say, 146.030Mhz and one on 145.150. BOS030 and BOS150 would probably be easier than trying to remember which is BOSTN1 and which is BOSTN2. Placing the names in the 270R memory is the last thing done, so don't worry too much about a name for the 270R's display just yet.
Most repeaters use CTCSS for access. Some newer repeaters use DCS. Some require or even prefer that no tone be sent at all. CTCSS is an analog frequency and a DCS code is digital data. The repeater may require one or the other to be present to "wake up" and begin retransmitting your message. All you really need to know about these two systems is the you need to match both the tone type and the tone value to successfully activate the repeater. Set the radio to your desired default power output level. Tap the VFO button once to enter VFO mode (if not already in VFO mode).
Enter the repeater's receive frequency by twisting of the tuning dial (page 13) or by direct entry (page 14) via the keypad. When using the keypad, do not enter the leading "1" of the frequency - as all the frequencies that this radio can tune begin with "1" and can not be changed. With the repeater frequency displayed, next enter the CTCSS tone for the repeater as described on page 23. If the repeater uses DCS, follow the directions that begin 1/3 of the way down on page 24 instead. As far as "TONE" and "TONE SQ" are concerned, the difference can best be described in that a radio working on a repeater system benefits from use of TONE, and a radio working on in simplex operation (no repeaters) benefits from the use of TONE SQ. Since we're programming repeater frequencies, there's no need to select TONE SQ. If the repeater strips the tone from its output, your radio will remain silent if set for TONE SQ. TONE is a much better match for our needs. Remember, you must use the DIAL to select the CTCSS tone frequency or DCS Code. Unlike the repeater receive frequency, it is not possible to directly enter the tone frequency or code via the keypad.
At this point, the radio should be displaying the recieve repeater frequency. Since automatic repeater offset is enabled - the 600Hz offset frequency and direction are set. The tone type and value for this repeater frequency have just been set in the previous paragraphs as well. Now it is time to write all this information to the radio's memory. This is detailed 1/3 of the way down on page 29 under "Memory Storage". Once you have performed step 5 in Memory Storage for this first repeater, it says to repeat this same process. This means setting the next repeater's recieve frequency, tone type and tone value - just as you have done with the first.
Once you have made sure that you have unique names assigned and the other information above, you are ready to begin adding them into the 270R's memory. You can go back add names to be displayed instead of the frequency of the repeaters if desired. Page 31 details the procedure to assign an alpha numeric name to each memory location. Make sure that you are assigning the correct alpha-numeric to the repeater by checking the frequency from time to time - don't blindly add alpha-numerics to memory channels.
This is a very tedious process. Ham Radio Outlet offers Windows programming software and transfer cable by Yaesu called "ADMS-270" for $38.95. This package allows you to easily create many lists of memories on your Windows PC & keyboard that can be uploaded and downloaded "on the fly" I highly recommend this software - or any software that allows you to program the radio from a computer rather than the radio itself.
I hope this was helpful.
Nov 29, 2012 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Where is the serial # located on the Master III?
Hi Jeff,
I'm going to take an edumacated guess here, look for a plate or sticker somewhere on your box, usually you will find it underneath the unit, it will not only have the serial, but the model as well.
I hope this is helpful.
May 04, 2012 | GE Vhf Master Iii Repeater With Tx/rx...
I have a ge27851f-2 cordless dual phone and both handsets say unavailable even when paired at the base.
If the base station is plugged into the phone line you should be able to designate one phone as the master. That phone should be on the base station when charging. If you look in the manual it should show you how to redo the master. It's usually just pushing a button when on the station. Just takes a second. That will also enable the phone to work with the base station. It locks out any phones that haven't been physically connected to the bases. To do the second phone you may have to do a slightly differant process to register it with the bases.
Nov 04, 2009 | GE 27851FE2 Phone
If i want to use a repeater station what channel do both us need to be on eg if i am on 1 does the other person has to be on 31
Your radio needs to be programmed for one channel to duplex. Duplexing is when a channel has a different frequency for transmit than for receive. (Not all radios are capable of doing this.)
A repeater listens on one frequency and then retransmits what it hears on another frequency. See your local radio dealer for more info, and to see if your radio is repeater capable.
Oct 13, 2009 | Motorola UHF 435-470Mhz Antenna VISAR...
Interference using maxon pm100 2 way radio
Hello susannebrown. There is a problem with the base station or repeater station. If your mobiles can communicate ok, you have problem with the base, check the antenna & coax connections. #2 Swap out a mobile with the base & test operation. If you can do this & found the culprate care it to the repair shop(less cost). #3 Swap has no effect or you can't, you have a repeater problem. Sorry, call a repair shop.
Sep 08, 2008 | Radio Communications
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Radio Communications Logo
111 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
