My sandisk USB pendrive is not working. I had un plug it from my computer when data was transferring from PC to USB. Pl tell me What to do? Anirban Mahanta anirbanmahanta@gmail.com
  • Computers & ... Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Mar 25, 2011
I have a 4 gb hp v165w pendrive. its data transfer rate is very slow(120kbps). how can i speed up it? please help me
Hi
This not the problem with the pen drive but with your USB port. Check and make sure you are connecting the pendrive to a USB 2.0v. if you connect to older USB port then your data transfer would get effected. If still you are connecting it to USB 2.0v only then try to un-install the ports in Device manager and restart the PC once done the windows will automatically install the USB ports again and this will solve the problem.
NOTE: IF YOU ARE USING USB KEYBOARD BE CAREFUL NOT TO UNINSTALL THE USB PORTS OR YOUR SYSTEM MAY NOT ACCEPT THE KEYBOARD SOMETIMES. DO AT YOUR OWN RISK.
AND DO RATE MY SOLUTION
Jun 30, 2011 | Computers & Internet
My Sandisk 4GB Cruzer wont work ... When i conect mu USB it wont flash and a bubble comes up on my computer saying unkown device please can anyone help me thank you,. And im on windows xp..
Hi!
Try plugging it to another USB port on your computer, preferrably a rare one.
Also, try plugging it to another computer.
If none of the above worked, I'm afraid the pendrive is damaged and have to be replaced.
You can take it to a special lab that specialized in data restoration in order to take the data out of it...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards and good luck,
Pelu.
Dec 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi I ve a sandisk pendrive 4 GB and its a new one..but when i insert it to my pc pendrive is not detected..but other pendrives are working in my pc.and the same sandisk pendrive when i insert it to other...
you may need some USB drivers for this particular pendrive
control panel admistrive tools,computer management,device manager you should see a yellow question mark? right click to reinstall drivers
hope this helps
Sep 05, 2010 | Computers & Internet
It shows this device can perform faster. the pen drive is slow
this is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
Jul 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen Drive 16GB not working on laptop but working on other PCs...
It sounds as though the problem is with your notebook, rather than the flash drive. Specifically, with the USB port you are plugging it into. If you have another USB on the notebook, try switching between the two, and see if it behaves any differently. Another thing that can cause a problem is if the USB port on your notebook is not USB 2.0. The older ports (as in, an older computer) didn't have nearly the transfer speeds of the newer standard.
Also, are you trying to run multiple USB devices on your notebook at once? That could cause problems as well.
Cheers
Nick
Dec 28, 2008 | Televison & Video
Sandisk cruzer micro 4GB
it may be because of the usb port of the system or the usb of the pendrive.................
Feb 08, 2008 | SanDisk 4GB microSD High Capacity Memory...
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
